Last edit by: IB Advertising
Browse all: Interior
- Dodge Ram 2nd Gen How to Replace A/C Evaporator
Step by step instructions for the do-it-yourself repairs.
A/C evaporator leaking inside cab
Yes I did. You were right it was behind a plate. I have another question, under the passenger dash, the black box is sweating right next to the blower. Do you have any sugestions on what can it be. My drain was not clog.
Did you install an elbow or one of the ac drain kit from the dealer? If you didn't your problem is not solved.
As for the sweating box, sounds like you may have excessive moisture inside the cab under the carpet. It needs to be dried out and for the next month or so when using the AC roll down one of you windows a very small amount to help with air circulation.
No all I did was, to check the drain to see if it was clog. The drain line was not clogged. So that's why I was asking about sweating of the box. Bwdakrt, I'm not going to drive the truck for about a month, and I live in Florida do you think for the time I'm not driving the truck it will dry out completely or do I need to do what you said?
It should dry out some. If it's possible to leave the windows down to allow some air circulation at least a small amount but it will get wet again if you don't do the 'fix' on the drain tube.
