Last edit by: IB Advertising
Browse all: Interior
- Dodge Ram 2nd Gen How to Replace A/C Evaporator
Step by step instructions for the do-it-yourself repairs.
A/C evaporator leaking inside cab
Hey Group,
New to this site, looks like a good one.
Question.......my evaporator is leaking inside the cab really bad (2004 dakota sxt), can't find the origin of the leak anywhere inside or out.
Any responce is greatly appreciated as it is becoming a "pool".
I have already found the low spot on the floor board and punched a small hole for drainage.
Thanks in advance,
Brad
Thanks in advance,
Brad
I would think it's your Drain-tube that comes out on the fire wall on the engine side
that's clogged up. It's hard to see. On the pass-side on the fire wall kinda behind
your evap-canister. You can try to unclog it GENTLY with a coat hanger using no
force what so ever or you run the risk of poking holes.
Your AC drain tube is not clogged...it's a Dodge design flaw. The drain tube is sticking straight out into the engine bay and when you're driving down the road, the air coming into the engine bay is forcing the water back into the cab.
A very simple fix. Pick up a 5/8" heater hose elbow at any parts store. Grind or file down the barb on one end, apply a little silicone and stick it inside the drain tube no more than 1/2". Allow the silicone to set up and your problem is over. The elbow will allow the water to drain and keep the incoming air from being forced inside the tube. I had the same problem with my '01 RT about 7-8 years ago and this simple fix has completely cured the problem. NO MORE WET CARPET!!
THESE INSTRUCTIONS ARE EXACT. I WILL NOT BE HELD RESPONSIBLE FOR YOUR INABILITY TO READ AND FOLLOW THEM!!
To all that replied, thanks...........
We sorta figured it was a design flaw because in the 7 years I've owned it I hardly ever use the a/c on a long trip but this last trip was a hot one and I used it the whole time at speeds over 70 most of the time.......
The tube wasn't clogged so I will fab. an extension for it when I get a chance, probobly run it down about a foot and that should take care of it..
Again,
Thanks to All
Brad
Again,
Thanks to All
Brad
Again,
Thanks to All
Brad
Again,
Thanks to All
Brad
The $2 heater hose elbow is cheaper and works just as well but it's your money and your truck. Whatever you decide to do, the main objective is keeping the carpet dry. Good luck.
Trending Topics
This picture is looking down on the passenger side of the firewall just behind the cylinder head. The tube you're seeing beside the elbow is the transmission fill tube. A little hard to see and find but it's there.
