Horsepower master list
Old Jun 6, 2011 | 04:00 PM
NickCornell's Avatar
NickCornell
Default Horsepower master list
I'm making this because I
Curious myself and I'm sure it would help others. Let's compile a list of mods/upgrades that increase horsepower. Who cares to start us off
Old Jun 6, 2011 | 04:15 PM
thunder98110's Avatar
thunder98110
Cams H.O, 206, 212, 218, 224x
Intake
throttle body
power wire
full Exhaust
SCT tuner
Sonnax/TMR mod
180 tstat
efan
weight reduction
drag slics
caltracs
Sharradon Valve body
Stall converter
Methanol injection
forced induction paxton novi 1k or 2k s/c
svt cobra injectors
Killians head work
gears and lsd upgrade
Old Jun 6, 2011 | 04:32 PM
NickCornell
Thunder you're a god
Old Jun 6, 2011 | 04:36 PM
bigreed91's Avatar
bigreed91
Harland sharp roller rockers, headers, edelbrock aluminum heads, m1 intake, magnaflow high flow cat, cold air intake, voodoo cam, 52mm throttle body, e-fan, sct tuner. Well thats my wish list atleast.
NickCornell
Svt cobra injectors? Do they fit? What year
Old Jun 6, 2011 | 04:49 PM
thunder98110
they fit aswell as cobra springs. only really need that stuff if you have a 224 cam and boost. #39 injectors work
Old Jun 6, 2011 | 06:11 PM
MikeCzipri's Avatar
MikeCzipri
http://www.ecrater.com/p/3666537/ele...bo-charger-all
Extra 400 RWHP and an extra 17 mpg.....
dodgeramguy85's Avatar
dodgeramguy85
Dodgeforum decal adds a average of 25 hp I think this list is complete now lol
Old Jun 6, 2011 | 06:22 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Here is some of what I got posted in the FAQ. TONS more listed. https://dodgeforum.com/forum/2nd-gen...ion-ideas.html
Engine Performance - More Displacement
_______________________________________________
Big Block Swap
http://www.bigblockdakota.com/gpage5.html
http://www.engine-swaps.com/
http://chucker54.stores.yahoo.net/192wddakensw.html
Small Block Stroker kit
http://www.krcperformance.com/krc/in...hk=1&Itemid=26
(408) http://www.moparstyle.net/technical/408stroker.htm
https://dodgeforum.com/forum/2nd-gen...hlight=stroker
http://www.carcraft.com/techarticles...ker/index.html
http://speedomotive.com/ps-140-13-mo...roker-kit.aspx
This chart will give you an idea of what bore and stroke will give you what size engine.
Engine Performance: Forced Induction and Nitrous Oxide
https://dodgeforum.com/forum/2nd-gen...rbo-build.html
http://www.theturboforums.com/smf/in...topic=131965.0
https://dodgeforum.com/forum/2nd-gen...t-options.html
http://www.dakota-durango.com/forum/...0&postcount=11
http://www.theturboforums.com/smf/in...?topic=80720.0
http://www.off-roadweb.com/tech/0902...ing/index.html (Nitrous for a 2001 Durango 5.9)
More Engine Performance Options
Lots of info on performance http://web.archive.org/web/200804121...sandtricks.htm
Larger Bore throttle body http://www.thefastman.com/Throttlebodies47.asp,
https://dodgeforum.com/forum/2065702-post1.html
Kegger mod https://dodgeforum.com/forum/2nd-gen...e-mod-diy.html,
Roller Rockers 1.7:1 Harland Sharp's http://store.summitracing.com/partde...7&autoview=sku
Much cheaper then the Mopar or Crower kits, and much easier to install in my opinion (no lash adjustments, no guide plates, fits under stock valve cover)
http://www.pavementsucks.com/tech/rollerrocker.php
https://dodgeforum.com/forum/2065727-post3.html
https://dodgeforum.com/forum/2nd-gen...r-install.html)
Cams
Mopar Performance computer (V6 http://www.bionicdodge.com/bionic/in...p?topic=8778.0)
High output coil + wires + cap and rotor
Spark plugs (Autolite 3923's is 1 step colder) (Autolite 3922 is 2 step colder, for supercharger/ turbo/ NOS)
Higher flow injectors
Headers (v6 https://dodgeforum.com/forum/2nd-gen...9-headers.html)
Open flowing exhaust systems
High flow cat
Lower (numerically higher) Rear End Gears
Transmission shift kit
Machine work (deck down block, heads) (Bore out cylinders).
Polish and port heads http://www.moparmusclemagazine.com/h...ing/index.html
Electric cooling fan
Electric coolant pump http://www.csr-performance.com/csr_pumps.html
Under Drive pulley's. (be-careful lots are 6ribs. Magnums use 7 ribs)
Lots more....
http://www.hughesengines.com/TechArt...es03012004.php (V6 Performance)
Hurts Competition shifter https://dodgeforum.com/forum/2230368-post6.html
TPS Throttle Postion, CPS Crank Position Sensors modification. Go HERE.
Old Jun 6, 2011 | 10:01 PM
NickCornell
Haha what on Earth is that
