taillight fuse
Old Jun 10, 2011 | 02:57 AM
quajodakota's Avatar
quajodakota
Default taillight fuse
Last week I got stuck in the mud and when I was getting pulled out I think the tow rope pulled on the wires that light up my rear license plate. The wires were striped and touching each other so I fixed them and went a long my way.
My problem is later that night I realized my taillights weren't working and as expected with that my dash light isn't working either. Blinkers and brakes work just not the tail lights. I am sure the fuse is blown or something simple but the only problem is that I cannot find the fuse for the circuit. I have checked in the circuit board under the hood and also the one were you open the driver side door. None of the fuses are labeled "taillights" or "dashboard" so I have looked at most all of the fuses and haven't been able to find any blown ones. So...what do you all think? Can anybody direct me to the correct fuse I should be looking at? Do you think it is a blown fuse at all? Thanks in advance!
*edit* it is a 2001 dodge dakota.
Old Dec 17, 2011 | 01:03 PM
lonewolf1's Avatar
lonewolf1
New Member
I had to replace my heater core and when I put my dash back together, ended up with the same light issue. Can anyone tell me what the fix is?
