I need Transmission Advice !!!
Old Jun 22, 2011 | 09:47 AM
1998.Dakota.5.2.4x4's Avatar
1998.Dakota.5.2.4x4
Default I need Transmission Advice !!!
i have a 1998 4x4 Dakota with a 318 and a 44re transmission..
the trans has recently started acting up and now it will hardly even get in gear enough to even roll down the driveway.
the first thing i noticed was it would hold out shifts till about 4 thousand rpm but then it would lock in gear at a stop light and force me to break and hold the gas a little to keep from stalling out..
but now i stick it in gear and you can hear a whine coming from what seems to be the torque converter but i really cant tell..
im having a really hard time finding another trans in my area and im just wondering if maybe the torque converter could be the only cause or if its a catastrophic failure and im just gonna need a whole new trans..
Old Jun 22, 2011 | 12:26 PM
1986JEEP's Avatar
1986JEEP
I had a 3.9 auto that did almost the same thing but did not look in gear the torque converter was the main problem with it i just had the guy replace what need to be replaced then i sold it and it is still going.
Old Jun 22, 2011 | 01:14 PM
1998.Dakota.5.2.4x4
ive been thinking about putting a manual trans in it but im not sure what all i'll need to replace... i would love to have a manual over a auto.. i know i will need to change the flywheel and find a pedal and hydro clutch but im not sure if i need to change the PCM or any of the wiring harness things around to make it work. and im sure to do it correctly i would need to swap out the stearing col too...im good with mechanical things but tranny's were never my strong point...
Old Oct 21, 2011 | 02:05 AM
redford8378's Avatar
redford8378
hello there I have a 99 durango 4x4 slt with 5.2 that has the same symtoms can you tell me what the fix was
Old Oct 27, 2011 | 10:58 PM
1998.Dakota.5.2.4x4
I had to do a full tranny build.. in my trans there was literally no good parts left in it.. pump was broken in 4 places i replaced all the electronics and juat did a complete 1900 dollars in parts build
Old Oct 27, 2011 | 11:01 PM
1998.Dakota.5.2.4x4
I checked just about every option availible for factory reman or replacment trans and with the bs warrentys and costs and core charges it was juat better and more cost affective to rebuild with good summit parts.. doing that eliminated all the dodge failure equipment and ive got 500 miles on my trans now and its working perfectly
Old Oct 28, 2011 | 03:26 PM
Phat Mike's Avatar
Phat Mike
when mine went out last year it was the part with the big spring and lock ring. it was a mess
Old Oct 28, 2011 | 09:52 PM
olsarge's Avatar
olsarge
master tech's Avatar
master tech master tech is offline
Section Moderator
Dodge Forum Moderator
Garage is empty, add now
Vehicle: Mits P/U , Dodge avenger(1996) .
Default Transmissions
If you guys and gals need information on your transmissions. I'm always on the forum. I have been with dodge and building transmission for 25 years. Or if you see me posting in the minivan or durango sections and sometimes in the Ram truck. Just send me a message.
__________________
Master Chassis tech, Transmission
Automatic and Manual and Suspensions.
Also repair front and rear diffs and all engine
repairs inc Diesel. A/C repair too.
Old Oct 28, 2011 | 11:49 PM
master tech
Site Moderator & Tech
olsarge
What was your question. When I mean I' am online aways doesn't mean every minute of the day. So if you didnt see me online and you had a question, you should have sent me a pm. Which I didn't have any.
Old Feb 24, 2012 | 05:23 PM
olsarge's Avatar
olsarge
Sorry to be so long replying. I think I was just posting your contact info for someone needing trans help and the whole msg didn't get posted.
