ASAP driver side valve cover.
Old Jun 23, 2011 | 05:30 PM
thunder98110's Avatar
thunder98110
while your at it change the orings on the injectors, so you dont have to go through the trouble of having gas spray all over your engine while driving like myself.
i also hope you have assembly lube.
Old Jun 23, 2011 | 05:40 PM
URBANRDNECK's Avatar
URBANRDNECK
yeah then I am in a little bit a situation here because I don't have that tool or a ride to go get it.... Well this sucks
Old Jun 23, 2011 | 05:50 PM
thunder98110
you can possibly remove the VC without disconecting the rail. remove the 4, 8mm bolts that hold in the fuel rail you can lift it up. theres a little slack in the line so you should be able to lift it up and give you more room to remove the VC. your going to need a buddy to hold the crank when you loosen the cam sprocket bolt as well as getting the cam lined up once its installed again.
Old Jun 23, 2011 | 05:57 PM
URBANRDNECK
Then this is also so foam tubing that is in my way I'm pretty sure its just something coming of a EGR valve. So i'm going to give that a shot.
Old Jun 23, 2011 | 06:02 PM
thunder98110
not sure what foam tubing you are are talking about.
Old Jun 23, 2011 | 06:11 PM
URBANRDNECK
Rubber my bad. it leads into your air intake.
Old Jun 23, 2011 | 06:13 PM
thunder98110
you can remove the vac. lines, makes it easier to get to things. or the pcv lines too that are on the both pass and driver side firewall on the back side of the intake.
Old Jun 23, 2011 | 06:24 PM
URBANRDNECK
God this is frustrating.
Old Jun 23, 2011 | 06:28 PM
thunder98110
the hardest part is just getting to the cams. as you are finding out. have you gotten that VC off yet?
Old Jun 23, 2011 | 06:44 PM
URBANRDNECK
Nope, but I may have just found a ride to the local auto parts store
