if a rocker fell off your pretty much screwed, it would have damaged the cam and possible crack the head. inspect the head! you will notice if a rocker is off. a guy in the 3g section had that happend and he ad to replace a bent valve, ended up pulling his head off like 3 times in a week to get it fixed
Just cracked the valve covers. All the rockers were on. I'm going to take out the cam on the passenger side and re install it. And I will check timing I just gotta charge up my battery a bit before I get started. Thanks for all your help guys seriously, I will keep you updated as much as possible
ok I found the problem. you know that little know on the end of the cam that slips into the timing sprocket? it partly broke off and grind-ed against the sprocket
Reason: Additional information
