Fuel pump adventure
Old Jul 5, 2011 | 10:41 PM
JackTheStripper5.9's Avatar
JackTheStripper5.9
Post Fuel pump adventure
Thought I'd give you guys some humor
Fuel pump went out in my truck and I've been going at it on and off and boy did I figure out a few things lol
Came to the conclusion that the bolts weren't coming off the correct way. My first attempt was to try and use a sawzaw with some tough blades on them. I couldn't get the right angle and was hard to get up in there to begin with. I ended up realizing I probably just made more work for myself and I'm going to need a grinder. I wasn't too keen on the idea of using a grinder next to a gas tank so I figured what the hell and cut the straps down with my sawzall.
Dropped the tank down, cleaned it out, now I'm waiting on the new straps, $29 with free shipping, fine. Got a grinder and 10 pack of cutoff wheels for $21 and went to town. Tomorrow I'll pick up the new hardware from the dealership...$20 for the studs, nuts, and u-nuts. Hopefully this is the last of everything I'll need.
Anyone else ever have a project just turn to hell like this? I mean I could of done a few things differently but that's why it's a learning experience. My best advice is to cut a hole in the bed if you got a bed liner lol
Old Jul 5, 2011 | 10:49 PM
JackTheStripper5.9
Oh and I considered taking the bed off but I didn't see any issue with dropping the tank. 2 bolts vs 8 bolts... I'll take 2. The tank only had like 2 gallons in it and I figured with 257k, it should be cleaned out(however it seemed pretty clean inside). You can unplug everything by taking the rear splash guard off. Didn't need to take my tire off like I heard. Seemed a lot easier than doing an f-body.
Old Jul 5, 2011 | 10:52 PM
dodgeramguy85's Avatar
dodgeramguy85
Should of saved time and just took the bed off. When I did my fuel pump I had my bed ready to come off in a hour. Then I just used a come along to lift my bed up using the steel beam in our garage. I did it all by myself and was so much easier than trying to get my skid plate off and my tank straps.
Old Jul 6, 2011 | 02:57 PM
ritualjman's Avatar
ritualjman
Well I will just pull my truck bed off when I change my fuel pump. I am getting the right amount of voltage to my fuel pump but I have low fuel pressure and have changed fuel filters cleaned my fuel injectors and took it out on a back road and just punched it right to the matt from the 60KM/H and still no change in pressure. Any ideas before I pull the bed off it and drop the tanks to change the fuel pump and clean the tank.
Thanks
Old Jul 6, 2011 | 04:27 PM
dodgeramguy85
Thanks
Low fuel pressure is a bad a pump. Nothing else can cause it to be low other than a leak but you would see that. 8 bolts 3 fuel filler screws,spare tire rod(was just a pin you pull) and tail light clips. I did mine the bed way so I could sand the frame and repaint it also, so I killed 2 birds with 1 stone.
Old Jul 7, 2011 | 02:35 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Today I removed my skid plate and dropped the tank and replaced the sending unit and reinstalled everything with in 1 hour. That is before you started replacing yours, not to mention the time to put the bed back on and adjust and tighten it all down. 1st Gen tanks and skid plates are the same as 2nd Gens.
Sometimes removing the bed isn't faster. But I do know how easy it is to do it.
I had to have 2 other friends help me lift the bed off when I did the rear leaf spring brackets for my SAS a few months ago.
A F-Body as in Camaro and Firebirds/Trans Am. LOL Ya I had to replace the fuel pump in my two different T/A's. That was a PIA completely remove the rear axle and still fought with the steel filer neck.
Old Jul 7, 2011 | 12:07 PM
dodgeramguy85
Yeah but dropping a 3/4 full tank of gas would of sucked for me plus I tried to take my skid plate bolts off and I couldnt budge them. It was my first time taking my bed off so im sure my time could improve.
Old Jul 7, 2011 | 12:23 PM
ebrperk's Avatar
ebrperk
I had to do this in my 88 Toyota. Dropping the tank wasn't bad but all the screws were rusted in and I broke each one. A one day project turned in to a five day project
Fun Fun
Old Jul 7, 2011 | 07:18 PM
Senate427's Avatar
Senate427
I remember replacing the fuel pump on my 93 Dakota and I found that it was easier to take the bed off. It took a little over 1 hour to complete whole project.
Old Jul 7, 2011 | 08:23 PM
98dakota98's Avatar
98dakota98
i lifted the driver's side of the bed up on my 97 and changed the pump like that. 4 bolts for the bed, 3 for the filler neck, and 3 or 4 for the splash guard. only took 45 minutes or so.
