Ghost in the drivers seat!
Old Jul 6, 2011 | 07:26 AM
Ibleave74's Avatar
Ibleave74
Default Ghost in the drivers seat!
I have the 04 3.7 and have posted many of the problems I've had with my truck, but no luck finding out what it is. Here's a new one. Anyone ever been sitting at a light, foot on the brake and all the sudden have the rpm's shoot up and the truck lurched forward for a split second?? Kinda scared the heck out of me. After the split second that it did it the engine went back to idling up and down as it has for the last month. hasn't done it since. No clue what's wrong with this thing. Still no check engine light and still running like crap. Just about ready to call it quits with this one.
Old Jul 6, 2011 | 10:58 AM
sxrsil3nt's Avatar
sxrsil3nt
I've had something similar with this but it wasn't in a Dak.
My 04 Grand Prix did this sometimes and it turns out that it was a clogged TB - so dumb right?
I took it in and apparently the last time the MAF and the TB were cleaned, some jackass mechanic used the wrong cleaner (which actually turned out to be somewhat of an adhesive) which caused my TB to get clogged like a **** which resulted in delayed, sluggish response.
Don't know if this is the problem for your Dak, but this was one for my GP!
Old Jul 6, 2011 | 11:14 AM
Blaze10's Avatar
Blaze10
put some fuel injector cleaner through it and then maybe take it somewhere to get the throttle body cleaned out good of the carbon build up and stuff.. maybe that is your problem
Old Jul 6, 2011 | 12:22 PM
Ibleave74's Avatar
Ibleave74
I cleaned the throttle body out myself with throttle body cleaner and I've ran sea foam through it as well as injector cleaner at different times. Still acts the same. No worse, but no better.
Old Jul 6, 2011 | 01:43 PM
moparman_2004's Avatar
moparman_2004
well mine use to do this and after i put on my fastman i cleaned out the iac really well and since then havnt had an issue with it would of replaced it but there about 90 bucks
Old Jul 6, 2011 | 02:20 PM
JonnyP87's Avatar
JonnyP87
Mine was doing something like that. I cleaned out the throttle position sensor as described in the DIY section and its been working so far.
Old Jul 6, 2011 | 03:22 PM
Ibleave74's Avatar
Ibleave74
TPS is new and I tried to clean the IAC valve, but am wondering if it's just to dirty to work right. It was caked with carbon. May try and get one and see what happens. The air inlet temp sensor is new as well. The only thing that isn't new sensor wise is the IAC valve.
Old Jul 6, 2011 | 04:58 PM
moparman_2004
ya i sprayed mine mine throttle body cleaner really good sort of scrubbed it down and soaked it for 15-20min used a air hose anddryed it out and blew out what it would its about the best way to clean them cause its all you can do short of replacing it
Old Jul 8, 2011 | 01:44 PM
Ibleave74's Avatar
Ibleave74
What are the chances it could be o2 sensors bad and their just not throwing a code?? I swear I think this thing is possessed!!!!! I'm wondering if I just have a vacuum leak that I can't find and it's the tranny causing it to feel like a miss when it hits 50 mph, but is fine once I hit 60. Has anyone read anywhere that Dodge is having plenum gasket issues with the 3.7?
