'98 v6 running too rich and I'm out of ideas
Old Jul 19, 2011 | 08:27 PM
DeafMike's Avatar
DeafMike
Default '98 v6 running too rich and I'm out of ideas
Been having problems with my truck since day 1. It had a cylinder that was misfiring, so I replaced the plugs and wires. Didn't correct the problem so I just replaced my upstream O2 sensor. Haven't really taken it out for a long enough drive to determine if that corrected the major problem - but I took the truck back to AutoZone to have the codes pulled as the CEL didn't go off after replacement.
Only thing that came out of the diagnostic was that my truck was running too rich - the minor issue that I assumed the O2 sensor would fix along with the major problem. Not really sure what to check at this point, as the plugs, wires, and O2 sensor are all new.
Mass Airflow? No fault there as far as the codes go. I'm looking for a simple, non-electrical solution that I'm overlooking. Maybe it'll just go away as I only replaced the O2 sensor not even 30 minutes ago, gotta go pick up my girlfriend from work in about an hour and that's a good 30-45 minute drive.
I'm just tired of the smell of gasoline offending my nostrils when I'm idling.
Old Jul 19, 2011 | 08:44 PM
MikeCzipri's Avatar
MikeCzipri
HAve you checked/ replaced the O2 sensors in the exhaust system? I have a different motor but on mine there is an O2 sensor right by each or the pre cats
Old Jul 19, 2011 | 09:00 PM
DeafMike's Avatar
DeafMike
Yup, just replaced the upstream O2 sensor. The guy that pulled the codes said the only problem was the upstream one and the downstream one was operating fine (one on either side of the catalytic converter.)
I'm gotta go pick my girl up right now though, she just called. I'll post back and see if its still acting up. More clues to pinpoint the issue if so.
Old Jul 19, 2011 | 09:05 PM
thunder98110's Avatar
thunder98110
maybe one of your injectors is malfunctioning and dumping more fuel in than necisary.
