TB questions
Old 07-19-2011, 08:49 PM
MikeCzipri's Avatar
MikeCzipri
MikeCzipri is offline
Default TB questions
Will a new/ higher flow throttle body increase torque and low end power?
I have a 3.7 V6...looking for ways to increase low end power.
Also, will it increase/ decrease MPG? I know there is a guy named Dan the FAstman or something like that...anyone know how to order from him?
Old 07-19-2011, 08:52 PM
thunder98110's Avatar
thunder98110
thunder98110 is offline
Fastman TB. is the company, thats who i bought mine from. it will increase throttle response, i didnt notice any loss in low end. just more responsive at lower rpms and throughout the powerband.
Old 07-19-2011, 08:57 PM
MikeCzipri's Avatar
MikeCzipri
I found his website. $180 sounds reasonable. I think with that and the tune you told me about I should be able to get a decent amount of power. You think another 20-30 hp is a reasonable expectation from the tune and the TB?
Old 07-19-2011, 08:58 PM
thunder98110
uhhhh, probably 5hp from the TB, and since your pretty much stock, 15 from the tune at most.
Old 07-19-2011, 09:00 PM
dirtbiker's Avatar
dirtbiker
dirtbiker is offline
Well I've got the 3.9 with a V8 TB, and as far as torque/low end, I didn't really notice a difference between the V6 and V8 TB. Like Thunder said, I noticed an increase in responsiveness throughout. Also not sure about increase or decreasing mpg, I would think it will increase but something in my system (I think an 02 sensor) is bad so that is keeping me from knowing whether I'm pulling better mpg with the V8 tb. Good luck!
EDIT: Just saw that you found one for $180. Look on ebay, I got mine for less than 50 bucks shipped I think.
Old 07-19-2011, 09:01 PM
MikeCzipri's Avatar
MikeCzipri
Yeah only mods I have are the ebay CAI, high flow muffler, 1 heat range colder plugs and took off the clutch fan. If I got 20 hp from the TB and tune and increased low end power I would be happy. Sounds like I can accomplish both for less than $500. How much was the tune for your truck?
Old 07-19-2011, 09:02 PM
MikeCzipri's Avatar
MikeCzipri
Since the 5.2 TB works on a 3.9...will the 4.7 TB work on my 3.7? They are basically the same engine just w/ 2 cylinders lopped off.
Old 07-19-2011, 09:06 PM
dirtbiker's Avatar
dirtbiker
Yeah my TB actually came off a 5.9. I think that the 4.7 tb should work for you. But again I'm not real familiar with those engines.
Old 07-19-2011, 09:12 PM
thunder98110
the tune is 265, thats the handheld and 3 canned tunes.
Old 07-19-2011, 09:15 PM
MikeCzipri's Avatar
MikeCzipri
Sweet. That's not bad at all. Do you know if a 4.7 tb will fit on my 3.7? I did a little research online and apparently some people say yes and some say the holes don't line up, if that's the case it's no big deal because I can drill and tap new holes.
Quick Reply: TB questions
