Coolant Help
This post made me curious about coolant flow. I read up on it in my Dodge Service Manual, here is the description:
"The coolant recovery container works in conjunction
with the radiator pressure cap. It utilizes thermal
expansion and contraction of coolant to keep
coolant free of trapped air. It provides a volume for
expansion and contraction of coolant. It also provides
a convenient and safe method for checking coolant
level and adjusting level at atmospheric pressure.
This is done without removing the radiator pressure
cap. The system also provides some reserve coolant
to the radiator to cover minor leaks and evaporation
or boiling losses.
As the engine cools, a vacuum is formed in the
cooling system of both the radiator and engine. Coolant
will then be drawn from the coolant tank and
returned to a proper level in the radiator."
So I guess I was partially correct on coolant flow. According to Dodge the reservoir returns coolant to the radiator, not the engine.
Jimmy
or boiling losses.
Jimmy
Right... That action is being caused by the engine (Water pump) but the fluid is sucked from the tank to rad then cycles through the engine...
When you turn your truck off heat builds up in the engine and pressure increases (Not sure what they are talking about vacuum..) I guess you could try and use that word.. and coolant is forced out by the wide open Radiator Cap through the hose and into that tank..
Restart the motor and it will draw fluid from it.
Also to say its used as an overflow is technically correct. If too much pressure (Caused by Heat buildup and the boiling of the liquid) occurs more fluid from the rad would go into the tank.. the tank has an overflow on it and this would be overheating.
I went through problems a lot like this when I did my water pump. It was a nightmare, the first water pump I installed I had the coolant mixture correct but there were problems with the pump so I had to take it off and install another pump and that is when I got the coolant ratio all screwed up. My truck ran like crap and used a lot of gas because I had too much coolant so it was running way too rich because it never got to normal operating temperature. I had to drain and fill and check it with the hydrometer until I got it correct and it was a PITA.
Jimmy
