new plugs @ 60,000 miles?
Old Jul 25, 2011 | 08:01 PM
stampede 04's Avatar
stampede 04
Default new plugs @ 60,000 miles?
I just hit 60,000 miles on my 04 3.7. The manual says to change the plugs now, but is it really necessary? It also says to change the lube in the differential. Is that really necessary too?
Old Jul 25, 2011 | 09:55 PM
00daksport25's Avatar
00daksport25
Depends on what plugs you have now and how hard you drive the truck.
Old Jul 26, 2011 | 12:32 AM
qcdakota5sp's Avatar
qcdakota5sp
The manual also says if the temperature is below 0C or something you should change your diff fluid much sooner. I do the front and rear diff's after the Montréal winters where we get to -25C overnight.
I'm not sure if it is actually 'needed' but just in case right?
Old Jul 26, 2011 | 06:34 AM
stampede 04
True, can anybody recommend some good plugs for the 3.7l?
Old Jul 26, 2011 | 06:45 AM
DakMan6704's Avatar
DakMan6704
Two words:
PREVENTATIVE MAINTNANCE.
Pay a little now, or a lot later, most likely when **** hit the fan with something else. At least thats always my luck...
Old Jul 26, 2011 | 10:37 AM
00daksport25
Autolite 3923's work pretty well with our trucks.
Old Jul 26, 2011 | 03:13 PM
stampede 04
cool, how difficult is it to remove the plugs on the 3.7?
Old Jul 26, 2011 | 04:52 PM
00daksport25
It isn't too difficult. U might have to remove the intake tubing to get better access. Use a swivel joint, it makes it a whole lot easier. Are you replacing the wires also?
Old Jul 26, 2011 | 05:40 PM
MikeCzipri's Avatar
MikeCzipri
I have an 04 3.7 too...change my plugs every 30k miles. Just go ahead and do both the plugs and rear diff fluid, better safe than sorry.
Changing plugs isnt hard at all. Just need a plug socket and some socket extensions.
Old Jul 26, 2011 | 09:18 PM
2001DodgeMan's Avatar
2001DodgeMan
I've got almost 98k on my truck,what's the diff fluid? How is that changed if needed????
