Radiator overheats
Old Jul 30, 2011 | 01:17 PM
wizard71jp's Avatar
wizard71jp
Default Radiator overheats
I have a 1999 dakota 3.9L that I think is plugged. took out thermo but still gets hot ~ 200 deg F or more...
TRIED A CHEM FLUSH LAST YEAR but still hot. can I blow this thing out? or do I need to replace the rad?
any suggestions are appreciated!! the Wiz
Old Jul 30, 2011 | 05:23 PM
00daksport25's Avatar
00daksport25
Check the radiator cap. That was what my problem was a few months back. The cap keeps the system pressurized, without it the radiator overheats.
Old Aug 3, 2011 | 12:03 PM
wizard71jp's Avatar
wizard71jp
tnx for the idea, but it is fine. the rad never lost coolant...
I replaced the rad on Sun, and it works COOLY now!! $170 for new rad + 2 hrs actual work time = $470+ that Car-X wanted... hardest part is getting the fan assy lined up when re-assembling.
NOTE: I put a small rope around a blade & wrapped end around bolt holding AC pipes, to hold up fan!!
oh - I didn't know how to connect the new tran oil pipes to the old hoses (and don't have correct tools to press them together, I guess) so just kept the old hoses.
now I'll put the thermo back in... does anyone know if the cooler temp causes BAD mileage???
Old Aug 3, 2011 | 12:22 PM
00DakDan's Avatar
00DakDan
Section Moderator
Congrats on the fix.
Cooler temps keep the truck in open loop longer and a richer mixture so yes, the mileage will probably be lower.
