a/c resistance
Old Aug 15, 2011 | 09:25 PM
chris1996's Avatar
chris1996
Angry a/c resistance
my dak burned the a/c resistance and i change it was cheap $16 dollars but 2 months later really last week it burned the new one again what could be i dont think is the resistance....? and is so ****ing bad drive with the windows closed with rain and with out A/C aditional fact it only works on the full speed and if i put it in a lower speed it stops working but the A/C light stay on some help please
Old Aug 15, 2011 | 10:27 PM
98DAKAZ's Avatar
98DAKAZ
Question confused
could you be more specific on what you have done and why?
So you say the fan only some what works is that it? but you do have A/C its the controls that are messed up?
Old Aug 15, 2011 | 10:43 PM
moe7404's Avatar
moe7404
wrong part? bad switch? once i had a 1982 2500 ram the air con went out, the contacts in the ignition switch for the air conditioner burned out. i replaced it, it happened again. so i put a relay in to carry the load for the a/c. it wasnt easy but it was really good after done.
Old Aug 15, 2011 | 11:07 PM
00DakDan's Avatar
00DakDan
Section Moderator
You say "a/c resistance." We call it the "blower motor resistor." Regardless, what was the condition of the connector when you changed it? Was it partially melted? If that connector isn't on clean and tight, it can melt. The fan draws a lot of amps.
The other possibility is that the motor itself is drawing too many amps.
Old Aug 16, 2011 | 12:58 AM
magnethead's Avatar
magnethead
this. melted 2 resistors on our old dually before replacing the pigtail.
Old Aug 17, 2011 | 08:17 PM
chris1996's Avatar
chris1996
i really dont know my mechanic changed it
Old Aug 17, 2011 | 08:22 PM
chris1996's Avatar
chris1996
nope nothing work only in the full mode no A/C no fan nothing
Old Aug 17, 2011 | 08:29 PM
chris1996's Avatar
chris1996
im tinking that is the pigtail what is giving me problems but anyways i will take it to an electrisist for a check
Old Aug 18, 2011 | 08:54 PM
chris1996's Avatar
chris1996
but anyways thnx to everybody for the help you give me a closer look into the problem
