Follow-up< ABS light, Brake light ON
Old Aug 18, 2011 | 04:20 PM
Titan12345's Avatar
Titan12345
Default Follow-up< ABS light, Brake light ON
Hi, Just trying to follow up with this. Some have offered some ideas, but I would like to see if someone had exact same problem? ABS light on, Brake light on dash both on. They seem to reset after each engine off period. Some vibration is felt in brake peddle when stopping on pavement. Feels like Antilock is kicking in for no reason. Most common anwer to problem is speed control on rear diff. but I do not have the speedo problem common to the suggested fix, but rather the vibration in the peddle when stopping. One person suggested having codes looked at, but will the truck code with the two lights out or does it need the engine light on? In other words, how do I know when the truck will store codes AND will it store codes from the brake system? I don't want to change the speedo sensor on the rear diff or begin changing any parts before I know or hear about an exact symptom as mine.
Your thoughts?
Thansks for your help.
John
Old Aug 18, 2011 | 04:28 PM
moparman_2004's Avatar
moparman_2004
i believe these have a abs module not sure were its at but that would be my guess i had both lights on when my ecm went out but it didnt effect driving at all
Old Aug 18, 2011 | 04:59 PM
Titan12345's Avatar
Titan12345
Default Abs
The module is behind the glovebox, I think. I have read many posts and sometimes it is as simple as the connectors. I will clean the connectrors first to see if that helps. I might also try bleeding the brakes. I noticed the brakes fluid was a bit low, but not enough to allow air in the lines.
Thanks
John
Old Aug 18, 2011 | 05:08 PM
moparman_2004
ya give it a try and go from there if not one more thing off the list and you dont know till u try it
Old Aug 18, 2011 | 07:57 PM
hmr4599's Avatar
hmr4599
My 2009 Dakota had both brake/ABS light on all times. Almost replaced sensor, but someone suggested that I check ABS fuze.... that did it, the fuze was blown. (#17 in fuze box)
Old Aug 18, 2011 | 09:19 PM
Titan12345's Avatar
Titan12345
Same lights are on , but when the truck shuts off, they reset. When driving and apply brakes, the brake peddle vibrates like ABS is kicking in and then both lights come on. The speedo works fine, so I didn't think it was the sensor on the diff.
John
Old Aug 18, 2011 | 09:47 PM
00DakDan's Avatar
00DakDan
Section Moderator
The CAB will store codes in memory so they can be read later. The truck can also be driven with the DRB connected if you need to duplicate the condition. It just plugs in under the dash and is portable.
Old Aug 18, 2011 | 10:14 PM
01KotaQuad's Avatar
01KotaQuad
I just had that problem and it turned out to be the master cylinder...went from a $1,500 quote to me buying a cylinder for $60 and do it myself and has been fine sense. I also lost my pedal a few days after my lights came on and ran thru an intersection with no brakes...
Old Aug 18, 2011 | 10:43 PM
Titan12345's Avatar
Titan12345
01KotaQuad, did you have the peddle vibration intermittant prior to the total failure and did the lights reset when you turned it off?
00DakDan, where do I find a reputable CAB to pull codes? Does it have to go to the dealer?
Thanks,
John
Old Aug 18, 2011 | 10:56 PM
01KotaQuad's Avatar
01KotaQuad
well i felt the pedal go a little soft a couple times...and the next day i felt something, then the lights came on... and it got to where it would go to the floor and i would let off and pump it to get it to brake...then it just went completley to the floor gone....had to use the E-Brake to get home...if your gettting some vibration i would think to bleed the lines...even pay a shop the $40-$50 to power bleed it from the master cylinder...
