P0031 and P0037 after o2sensor changes
Old Aug 24, 2011 | 04:17 PM
weedmonke25's Avatar
weedmonke25
Default P0031 and P0037 after o2sensor changes
Hey all. I have a 2003 Dakota quad cab 3.9l v6. I was getting o2 sensor codes, and after looking at the state of them (they looked original) I replaced the upstream and downstream o2 sensors. I've read in other forums that bank 1 means drivers side, bank 2 means passenger side, sensor 1 upstream, sensor 2 downstream. If this is correct, the sensors I replaced ( the only o2 sensors there are on my truck) are bank 2 sensor 1 and bank 2 sensor 2. I'm now getting codes P0031 and P0037, which relate to Bank 1 heater circuits, and my truck does not have o2 sensors on bank 1. Could this be a ecu problem?
Old Aug 24, 2011 | 07:24 PM
weedmonke25
now i see i'm throwing a p0132 code as well. all of these codes refer to o2 sensors that don't even exist on my truck. what gives?
Old Aug 25, 2011 | 09:54 AM
weedmonke25
Default *RESOLVED* fuse in PDC
Just incase it might help someone in the future...found fuse U in PDC under hood was blown. Must have shorted out a wire during install. P0031, P0037, P0132 all disappeared after fuse replacement, CEL light is OFF, and truck is running great!
Old Sep 14, 2011 | 07:52 PM
fewalsh's Avatar
fewalsh
Default What fuse did you replace?
I'm having the same problem on my 2002 3.9l, however I don't see any under hood fuses related to the O2 sensor or labeled "U". Would they really change the wiring harness from 2002 - 2003?
Old Sep 14, 2011 | 09:44 PM
00DakDan's Avatar
00DakDan
Section Moderator
Make that 2001-2003, it was fuse U then as well, in the PDC.
Not sure on your 2002, in 2001 there is a vertical row of 4 fuses just above two rows of horizontal fuses. "U" is the right most fuse.
Old Sep 16, 2011 | 10:18 AM
fewalsh's Avatar
fewalsh
Thanks. Found it. Fuse had been completely removed (!) which is why I missed it when looking previously. Lights are off and all is well!
