I'm planning to run more boost than he did. just not right away. Meth injection is a really good idea too. But there will be an intercooler in time if I do go this way. I wwas thinking about doing this in stages. Stage 1 = X<10 lbs of boost and just get all of my gauges and sensors hooked up. Fuel pump upgrade Stage 2 = intercooler plus meth. 224 Cam swap and Beehives, Stage 3 = cosmetic HG, arp head studs and est. 20lbs
Will do, and yes it will be nasty. depending on how it goes I might try to have to different setups street ( less timing, less boost) and Strip (high boost, added meth, max timing, Slicks)
Ive thought of a radius arm SAS for the dakota, when I put a 4BT in there, i dont wanna have to redo the whole front end cause of stupid IRS, I wonder if a radius arm will hold the weight nicely
Yes it would be Badass-ness to the extreme! i just am trying to figure out how I can mount the SC before I go and blow 2k in random part money.
Well man, you know If I had a chance to see the truck and a borrowed unmounted SC, I could easily say put it here and run it this way, you know I can think of things on the spot pretty much.
Edit, Find out the size of the SC Itself, take a piece of cardboard and cut to the length needed then fold it aorund and tape it, then do a fake SC test fit in your engine bay, then pretty much you shall have a rough idea of what itll end up looking like and how to go about it!
