Is my MAP sensor bad Help ?
Old Sep 13, 2011 | 12:39 PM
98DAKAZ's Avatar
98DAKAZ
Default Is my MAP sensor bad Help ?
I posted a day or two about my engine running rich.
Well I decided to remove the MAP sensor and clean if possible and well I don’t think its cleanable but I did notice the tube on the manifold and little rubber elbow had a blue color film on them like some form of corrosion I wiped it all down removed the blue stuff and reinstalled it now my truck runs kind of fast at idle I have not driven it yet it idles down slow now also.
So is my MAP history?
Old Sep 13, 2011 | 12:55 PM
98DAKAZ's Avatar
98DAKAZ
Default well its ok now ?
After driving it its back to normal now.
But what was that blue stuff is it a indicator its going bad?
Old Sep 13, 2011 | 01:31 PM
URBANRDNECK's Avatar
URBANRDNECK
I have no idea what would cause a blue film maybe its the material starting to deteriorate? I think that means that the part is getting old and probably could be replaced.
Old Sep 13, 2011 | 01:47 PM
thunder98110's Avatar
thunder98110
im not exactly sure what your talking about, but my MAP sensor has a blue rubber oring on it. is that what your talking about?
Old Sep 13, 2011 | 01:48 PM
thunder98110
http://cdn1.iofferphoto.com/img/item...2/093/jxo3.jpg
Old Sep 13, 2011 | 02:38 PM
98DAKAZ's Avatar
98DAKAZ
Default no not a seal or ring
it was like a film on everything strange, my map is for a 2.5L remember guys not the V8.
You cant clean this MAP its a tiny tiny hole looks like this http://www.rockauto.com/catalog/moreinfo.php?pk=40733
And my truck is running just fine now
This is the stuff I used a Q tip to clean it
Old Sep 13, 2011 | 02:59 PM
Rakaric's Avatar
Rakaric
Well, I know that sometimes reusable air filters can sometimes have the oil from it get stuck on the MAP sensor overtime. I don't know what else could cause that.
98DAKAZ's Avatar
98DAKAZ
Default looks like cooper corrosion don’t it
looks like copper corrosion don’t it
Old Sep 13, 2011 | 03:01 PM
98DAKAZ's Avatar
98DAKAZ
Default never uesed one
never uesed one of those filters
Old Sep 13, 2011 | 03:10 PM
magnethead's Avatar
magnethead
same map as the pushrod motors. I replaced mine out of habit with the new TB. Not sure what would cause the dye, although I have seen decomposed rubber turn blue...
