Mph's dropped 5mph, blue smoke out tailpipes, pulled over and now wont start
Old Sep 16, 2011 | 01:13 PM
logicsound's Avatar
logicsound
Default Mph's dropped 5mph, blue smoke out tailpipes, pulled over and now wont start
So I am driving down the highway (1999 Dakota sport 4x4 5.2) and the mph's dropped about 5mph and then it became slugish and I pulled over and shut it off. Now it will not start.
Background: I have been burning oil and been putting in about a quart a month and it has been overheating but was only a little hot at the time the engine cut out.
The engine will turn over and is throwing no codes, Oil level is good, I tried pouring gas in the throttle body and it still wont crank. it has spark What are my next steps? Thanks for any help!
T
Old Sep 16, 2011 | 01:20 PM
thunder98110's Avatar
thunder98110
your probably blew your headgasket. is there oil in the coolant?
Old Sep 16, 2011 | 01:44 PM
logicsound's Avatar
logicsound
Thanks for the quick reply, I just pulled off the radiator cap and then a leak started, as far as I can tell its coming from the waterpump, its leaking down onto the damper. I didnt see any oil, just water and coolant. Where is the drain for the radiator so I can see if theres any oil in it? and what are you thoughts on the leak after I pulled the cap?
THANKS!
Old Sep 16, 2011 | 01:48 PM
thunder98110
since you said you over heated, and your adding oil and burning it, i still be its the headgasket. not sure about the coolant leak. i think there is a petcock on the bottom of the radaitor somewhere. not sure exactly on the magnums.
Old Sep 16, 2011 | 02:08 PM
logicsound's Avatar
logicsound
ok, found the peacock but turning it did nothing, pulled the bottom hose and it drained out, not much in there at all! maybe a gallon (not sure how much is suppose to be in there) didnt see any oil in there but tons of dirt and grit. How can I tell for sure that the head gasket is blown? before I tear it all down?
Old Sep 16, 2011 | 02:14 PM
thunder98110
compression test
Old Sep 16, 2011 | 02:35 PM
00daksport25's Avatar
00daksport25
For the petcock, you need to turn it and then pull it out slightly.
Old Sep 16, 2011 | 02:38 PM
logicsound's Avatar
logicsound
oh, I guess that would help...Thanks! Working on checking the compression now.
Old Sep 16, 2011 | 02:58 PM
98DAKAZ's Avatar
98DAKAZ
Default I never use the little drain valve
I never use the little drain valve I did at one time till a few just snapped off on me or would never close all the way so now I just pull the lower rad hose faster and no worry of a snapped off valve or a leaky valve.
Sounds like it needed a system flush.
You may have a half plugged rad by the sounds of what you say when you talk about all the grit that came out a new rad may be in order.
Old Sep 16, 2011 | 03:07 PM
logicsound's Avatar
logicsound
yea tried pulling petcock out wouldnt budge, just pulled hose.
