transmission problem
Old Sep 16, 2011 | 03:50 PM
fxdwg94's Avatar
fxdwg94
Unhappy transmission problem
my trans won't shift out of 1st gear trouble codes are p0700 trans control sys malfunction,and p0760 shift solenoid c malfunction i would like to know if i can fix either of these problems ?
Old Sep 16, 2011 | 04:03 PM
thunder98110's Avatar
thunder98110
one of my friends had gotten his fluid changed at jiffy lube, and they cut a 4x4 filter in half with a hack saw and installed it in his 2wd dak. every 6 months he thew a p07xx code for the trans, the fix was to drop the pan, exchange fluid and proper filter and it would go away. i doubt that happened to you, but its probably your solenoid thats gone bad.
Old Sep 16, 2011 | 04:05 PM
thunder98110
https://dodgeforum.com/forum/3rd-gen...sion-code.html
just as a reference, but like i said, the filter is probably not your problem.
Old Sep 16, 2011 | 04:17 PM
fxdwg94's Avatar
fxdwg94
do you know where the solenoid is at thunder
