Trying to help my boss his 99 dakota shifts at 5000rpm
Old Sep 17, 2011 | 08:28 PM
Y2kkustomes's Avatar
Y2kkustomes
Default Trying to help my boss his 99 dakota shifts at 5000rpm
my boss has a 99 dakota v6 2wd it shifts from 1st to second at 5000rpm
he has changed fluid and filter and checked for power at all conections
where is the shift sensor what should i check any ideas it still does it after fluid and filter change and some times its fine so i know it has to be electrical just dont wanna randomly jump at stuff. thanks guys
Old Sep 17, 2011 | 09:59 PM
thunder98110's Avatar
thunder98110
can he shift when he wants if he uses the collum shifter? ie: have it in 1, then drive to 10 mph then shift to 2 with the lever?
Old Sep 17, 2011 | 10:02 PM
Y2kkustomes
yes but i will have to double check where are you going with this? so i can get to the next step when i find out. thanks
Old Sep 17, 2011 | 10:09 PM
thunder98110
i really dont know, it could be the shift cables that need adjusting.
Old Sep 17, 2011 | 10:23 PM
Y2kkustomes
sorry i do know its electrical but thanks
