02 Dakota Drive shaft issues "HELP"
Old Sep 20, 2011 | 06:59 AM
raysgpa's Avatar
raysgpa
Talking 02 Dakota Drive shaft issues "HELP"
I have a 02 Dakota,V6 automatic,4X4 ext cab and the front drive shaft, front pancake joint failed. From my research i see the same year in a standard trans has a double u-joint front drive shaft. Anybody know if i can replace the OEM with the standard trans version ?
Old Sep 20, 2011 | 07:59 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I moved this thread to the second generation Dakota section,
FF
Old Sep 20, 2011 | 09:53 AM
McNasy's Avatar
McNasy
just went through this a month ago, they say the only difference in the front shaft IS if its a manual or automatic trans. the manual trans i beleive it is longer than the auto. the aftermarket shafts come with 2 u-joints instead of a cv joint and a u joint. i have a AWD and put in 3 of the aftermarket shafts and none of them fit correctly. no one at the part stores could figure it out. they all told me to buy an oem from the dealer. weird. so to answer your question. no, a standard wont fit in an auto. Welcome to the forum!
Old Sep 20, 2011 | 03:33 PM
Phat Mike's Avatar
Phat Mike
I took mine to a local drive line shop and they fixed mine up! cut off the weird pancake joint and had a custom U-joint style that was put on. you may need to check around your area.
Old Sep 21, 2011 | 08:53 AM
McNasy's Avatar
McNasy
how much did you pay for them to fix yours? i can get one from a stealership for $325.
Old Sep 21, 2011 | 01:02 PM
Phat Mike's Avatar
Phat Mike
IIRC it was around 125.00 area.
Old Sep 28, 2011 | 06:35 AM
raysgpa's Avatar
raysgpa
Default 02 Dak front Driveshaft update
The front Drive shaft pancake joint failed at 140.000 miles.Finely found a local drive-line shop. new front OEM joint cost me 160.00 and They would have done a double u-joint shaft at my request. Wicked awesome,old school place. super folks. Just thought in another 140.000 the Michigan cancer will claim my Dak. OH well time to move.
Old Sep 28, 2011 | 06:42 AM
raysgpa's Avatar
raysgpa
all right a pic to come. thanks for the help
Old Sep 28, 2011 | 07:59 AM
1969CoronetR/T
vaffanculo
echo....
