A sound i can't figure out
Old Sep 22, 2011 | 09:25 AM
spshultz's Avatar
spshultz
This might sound stupid but on a cold morning you could jack up one wheel at a time and give them a couple of really good spins to see if the sound is there. No weight on the wheel may change the dynamics of it but it may help in locating the sound.
Old Sep 22, 2011 | 11:36 AM
chris1996's Avatar
chris1996
Originally Posted by jrmikucki
no no thats fine thank you, yes the sound is always there nothing makes it go away except a warm day and that is it. To better explain the type of noise it sounds like brakes rubbing against the rotors, and yes i did check those as well to make sure it really wasn't them rubbing together.
change the front brake pumps seals mine do almost the same
Old Sep 22, 2011 | 11:40 AM
chris1996's Avatar
chris1996
nope that's not stupid is almost what you need to do mine do a strange sound in the front brakes and it was the the front brake pump seals the didn't have the strength for disconnect the pads
Old Sep 22, 2011 | 12:47 PM
jrmikucki's Avatar
jrmikucki
chris 1996 thats almost what it sounds like, like the breaks are rubbing cause the sound close to to rotor. But would the col weather affect that?
spshultz thank you for the advice i never thought of doing that i will try that then.
Old Sep 22, 2011 | 01:23 PM
chris1996's Avatar
chris1996
idk my country isnt as hot but is probably... when is hot is easier to transport the oil for the pumps... but do this push the truck while is turn off and cold from the front tire and hear if the brakes sounds
Old Sep 22, 2011 | 07:32 PM
GreenDak22's Avatar
GreenDak22
Another question: I'm not sure how to ask it properly, but do you 'feel' the noise. Like does the steering wheel vibrate when you hear the noise or feel something rubbing/grinding/scraping through the floor where your pedals are...Something of that sort?
Also, your post about the wheel cylinders...those are used in drum brakes, and I can only assume you have rotors in the front. But maybe the mechanic who told you that mixed up wheel cylinders and pistons (which are for the calipers/rotors). Not sure what I'm getting at here haha, just trying to brainstorm.
Old Sep 22, 2011 | 07:34 PM
GreenDak22's Avatar
GreenDak22
Another thing, is your Dakota rear-wheel drive or a 4x4?
Old Sep 22, 2011 | 07:48 PM
jrmikucki's Avatar
jrmikucki
no i don't feel the noise at all, no vibrations, nothing. it is a 4x4. i might as heard the mechanic wrong too and might be getting it mixed up myself haha.
Old Sep 22, 2011 | 07:51 PM
chris1996's Avatar
chris1996
the second kind of sound, well i take my brakes to the mechanic (just for safety leave it to the pros) and what i know is that the thing that caused the sound in mines is the brake pump seals... and then you need to bleed the system but that's all i know about it... and mine is a 4wd hope to be helpful
Old Sep 22, 2011 | 08:39 PM
GreenDak22's Avatar
GreenDak22
Can't feel anything, you say. Hmm, that's pretty strange. Have you checked to see if all the fittings and joints are greased up...or does anything on the front-end need replacing?
And Chris1996 seems to have a good point, too.
If you do bring it back to the shop, ask them to take a look at the brake pump seals.
