Headers for the 2.5L
Old Oct 30, 2013 | 02:44 AM
DurdyGP's Avatar
DurdyGP
Do those headers work on the stock 2.5 heads an also would the ones from pace header for the 2.5 jeep work there much cheaper in price but the drop is what im worry about im jus tried of the stock ones cracken im going on my 4th set I got a 97 sport 5 spd
Old Oct 30, 2013 | 06:07 AM
98DAKAZ's Avatar
98DAKAZ
Cracking?
Never had any problem with my stock headers
Yes the banks will fit the other I don't know
Are you some place that gets a lot of rust and they rust a lot the stock ones are very thick?
Do you drive through a lot of water every day?
Old Oct 30, 2013 | 08:47 AM
00daksport25's Avatar
00daksport25
Yea, i know what you mean. The stock manifold is cast and cracks easily. Mine was. The Banks will bolt up to your stock downpipe, a bit tight, but it will work. The Pacesetter one will fit the head, but you'll need to modify your stock downpipe.
I have the Banks header with a custom 2.5" downpipe. Sounds and feels great. Oh and no cracking.
Old Oct 30, 2013 | 04:53 PM
DurdyGP's Avatar
DurdyGP
Thanks guys now I just need to get funds to get it done I live in riverside , ca I not sure why they crack I was told its cuz there cast but yes those banks ones look nice just a bite pricey thou
Old Jan 15, 2014 | 04:28 AM
DurdyGP's Avatar
DurdyGP
Btw I got the banks an there on I hear a exhaust leak thou I hope the shop thighed all the nuts but I been on a mission tryn to find out im getting I code 1294
Old Jan 15, 2014 | 05:20 AM
98DAKAZ's Avatar
98DAKAZ
P1294 (M) Target Idle Not Reached
It sounds like what you may be hearing is a vacuum leak not an exhaust leak.
Your idle is low you have an intake leak a bad TPS or IAC is dirty clean the throttle body.
So you like the new exhaust? That's the one thing I still want to do on my 2.5
Old Jan 15, 2014 | 11:22 AM
Bigboi407's Avatar
Bigboi407
i would like to get these headers as well in the future, i KNOW the 2.5 will breathe better, now that ive bored my 2.5 to .060 over with a 4.0 throttle body and a brand new head, it feels much more restricted than ever before
Old Jan 15, 2014 | 02:13 PM
DurdyGP's Avatar
DurdyGP
Its got a high idle backfires when im stop an theres a miss fire mid shift
Old Jan 15, 2014 | 02:16 PM
DurdyGP's Avatar
DurdyGP
Its got a high idle backfires when im stop an theres a miss fire mid shift I changed the two sensors on the TB cap rotor plugs plug wires o2 by the header check my lines in the engine compartment im just lost
Old Jan 15, 2014 | 02:44 PM
Bigboi407's Avatar
Bigboi407
that is the reason why i wont let anyone touch my engines, EVER....
You put the Banks header on, it ran fine, and now its running like crap, misfiring, high idle and youve checked sensors, sounds like the intake/exhaust bolts are loose which would give you a vacuum leak, or you have a vacuum leak elsewhere causing too much air to get in
