chuggle ?> & IAC
Old Oct 8, 2011 | 12:13 AM
jondakotaguy's Avatar
jondakotaguy
Default chuggle ?> & IAC
Today; I was out and I rev'ed the engine up to 3K and kept it there a min or two.. then compleatly backed off.. and let it catch its idle. It did not die; but kinda had a miss to it.. like the IAC didn't open fully; in time.. or w/e..
Is this a clear sign of a failure or at least problem with the IAC? I hear a 'CLICK' sound coming from the area when its cold when it frirst starts and kinda chuggle chuggle from time to time.
1997 5.2L
Old Oct 8, 2011 | 01:12 AM
tbeck1985's Avatar
tbeck1985
Here's a write-up on how to clean it. Can't hurt if this isn't the problem, plus we can then rule it out.
https://dodgeforum.com/forum/dodge-r...n-the-iac.html
Old Oct 8, 2011 | 09:37 AM
jondakotaguy
Yeah thanks; but I actually tore the whole TB down and completely cleaned it a long time ago and is still clean; Like i said i hear ti "THud" or "CLICK" sound every so often like its in a bind.. I know it works cus i can watch it open pre-ignition; and close (We know there is a gab always so close is extend all the way out)
But um.. it might have been pushed/pulled by mistake; I cant be sure.
Old Oct 8, 2011 | 09:02 PM
jondakotaguy
I'm so tired of Dodge... Can't get nothing to work right.. So since I took the defective magna-crap off.. and put the Catco; the power is **** poor. I've felt better 4 bangers than this. This is pathetic already.
Old Oct 8, 2011 | 09:53 PM
thunder98110's Avatar
thunder98110
somethings wrong with your engine then b.c catco has been proven to be better than the POS stock cats.
Old Oct 8, 2011 | 10:55 PM
jondakotaguy
Yeah there is something wrong with my engine; a miss of some sort.. cant find it already done everything. tracking down.. thought it was gone b4 by adjusting rockers and replacing one.. but noooo... I just didn't notice it.. cus i've been driving long distances lately... but i got back into my usual routine.. short runs and stuff and going out to the pits. and its still there.. ROFL..
FCKING truck.... I am really starting to hate this truck.. then to top it all off; i got re-ended the day I was going to the muffler shop to get the catco on..
The catco feels like stock.. but the actual motor has no change since the replacement of the magna-crap..
And its not the plenum; had it checked and its fine;.. clog up the Fresh air side and it builds suction.. glog the PCV port on the motor and no suction on the fresh air side; actually; when you let go it bursts out built up pressure for a micro section which is normal; else it would not do either and pull it through the "Supposed" leak.
Maybee give me time and i can collect my thoughts and then maybe try and find the most sensible place to start.. Probably drop $100 bucks at the dealer for diagnostics.. I'm tired of throwing money at this thing..
Old Oct 8, 2011 | 10:56 PM
jondakotaguy
Oh.. Did I tell you; when you first push the throttle; it feels like it wants to go for a micro section; bogs down sorta.. Does this sound like the MAP?
Old Oct 8, 2011 | 11:01 PM
jondakotaguy
Oh.. and it has random crappy shifting points.. too! Joy huh? Yeah.. Sometimes 1st shifts with power and authority other times it shifts like I'm on a moped. Oh.. and 2nd to 3rd I think.. kinda floats "finding the gear"
its all random as hell though.. turn a corner and try to accelerate.. it doesnt do ****.. unless you really give it gas; and most the time.. nope; no passing gear.. wants to wind through the gear its in.. and it wont drop down.. (nothing wrong with the cable)
I know this truck has the potential and has power; I've felt it.. come and go..
Old Oct 8, 2011 | 11:02 PM
jondakotaguy
I mean man.. i'm so fed up I'm about to rap this truck around a tree or drive off a damn boat ramp.. and collect the insurance check..
