Govenor Pressure Sensor (need to replace)
Old Oct 19, 2011 | 11:31 PM
master tech's Avatar
master tech
Site Moderator & Tech
The Mopar part numbers are 4617210 governor solenoid, 5602819AD transducer sensor, 52118789 trans filter, and 4295875AC pan gasket. I would buy mopar parts, Because you don't know if you will get the right parts from the other stores. You do know the picture in your first post is a 46RE transmission?
Old Oct 21, 2011 | 08:18 AM
2000DakotaQuad's Avatar
2000DakotaQuad
Where do I buy Mopar parts? At the dealer only? Yea Master Tech I found th epic and just posted it as a reference. I was told by all these trans shops that the sensor and solenoid were a pain to get to and required hours of labor. After reading up and seeing that pic I was so pissed. I hate mechanics.........worse than lawyers
Old Oct 21, 2011 | 10:21 AM
00DakDan's Avatar
00DakDan
Section Moderator
I'd probably refine that comment if you're looking for help. Lots of mechanics are on this site and at least 2 are trying to help you now.
You can get Mopar parts from your dealer or online. Google is your friend.
Old Oct 21, 2011 | 11:21 AM
dodgeramguy85's Avatar
dodgeramguy85
Took the trans shop 4hrs start to finish to get the one done in my moms jeep. Call around and see what trans shops are charging.
Old Oct 21, 2011 | 12:23 PM
2000DakotaQuad
I called around a while back and the going rate was about 400-500 and since we just bought a house thats not going to happen.
Old Oct 21, 2011 | 12:30 PM
2000DakotaQuad
Called my local dodge scam, I mean dealer and
4617210 governor solenoid 158.96
5602819AD transducer sensor 124.71
Way more expensive then Napa or other part stores but if I have to I have to
Old Oct 21, 2011 | 02:37 PM
00DakDan's Avatar
00DakDan
Section Moderator
How's less than $100 for both and the numbers cross reference. There are lots of places to check. Here's one:
Solenoid:
http://www.transmissionpartsusa.com/...-000053396.htm
Sensor:
http://www.transmissionpartsusa.com/...-00053397a.htm
Do get a filter from the dealer though. Aftermarket ones are crap.
Old Oct 22, 2011 | 04:47 PM
2000DakotaQuad
ok so the governor pressure sensor and solenoid are changed. I went to the local junk yard and took them out of a 2000 ram V6 (yes same trans model number and same part numbers) I paid 10 dollars for the parts and not the 270.00 my local dodge dealer wanted for them. I then went and got a new trans filter and gasket and got to work. Very easy job. Took maybe 30-45min if you take out the draining time. It is shifting again but the service engine light has not gone out. When should a expect that to go out
Old Oct 22, 2011 | 06:18 PM
dodgeramguy85
Might have to unplug the the battery for a little bit.
Old Oct 22, 2011 | 07:43 PM
2000DakotaQuad
the check engine light went out after driving around a bit. I called and asked the dodge dealer how much trans fluid i needed to put in and the guy said 4-5 qt if you didnt empty the crankcase and also told me to check the level in park......both are of coarse wrong. After checking the level in N as it states in the service manual I added about 9 and a half or so and i am right at the fill mark in N. And they wonder why we fix this stuff ourself. i feel safer doing it myself then having them do it. Anyway I will let you know how it goes. so far so good
