Peplacing Power Steering Transducer
Old Oct 18, 2011 | 01:52 PM
Missed Again's Avatar
Missed Again
Default Peplacing Power Steering Transducer
Last January I had to have the power steering pump in my 2000 Dakota replaced. Ever since then the check engine light comes on. I have been told it is because I have a bad pressure transducer or the pressure may be too low. I have no problem steering the truck so I’m assuming the pressure is satisfactory. My question is how much trouble is it to replace this transducer and where do I find it.
Old Oct 19, 2011 | 01:42 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd Generation Dakota Sub-Forum.
Old Oct 19, 2011 | 08:28 PM
00DakDan's Avatar
00DakDan
Section Moderator
It's visible from above, just behind the power steering cooler. Just follow the steel line from the pump and you'll see it.
It's very easy to replace, it's threaded.
Old Oct 22, 2011 | 06:21 PM
Missed Again
00DD - Thanks for the tip, I knew it couldn’t be too difficult as the folks at the Dodge dealership only wanted $190 to fix it. Once I knew what to look for I found the Yoyo that put in the PS pump didn’t plug the pressure transducer back up, the connection was just dangling there. What makes it doubly bad is the guys at the DD garage didn’t see to do it either, they wanted to replace the whole thing.
Old Oct 22, 2011 | 07:52 PM
00DakDan's Avatar
00DakDan
Section Moderator
Glad you got it - and it was an easy fix.
