5 speed help please
Old Oct 23, 2011 | 11:48 PM
Reddak's Avatar
Reddak
Default 5 speed help please
Finishing up my swap from 3.9 to 5.2. The only problem is the truck isn't gonna start because I have a 5 speed and the engine harness is for an auto. Can I rig it for the 5 speed clutch sensor?
Old Oct 24, 2011 | 08:21 AM
00DakDan's Avatar
00DakDan
Section Moderator
What do you mean "clutch sensor?"
Old Oct 24, 2011 | 02:35 PM
Reddak's Avatar
Reddak
There are two sensors on my 5 speed. One is for the speedo and the other I believe is for the clutch
Old Oct 24, 2011 | 03:09 PM
00DakDan's Avatar
00DakDan
Section Moderator
There is no sensor for the clutch on the tranny. There is a clutch pedal switch, later models, so you can't start it without depressing the pedal.
What year?
You aren't looking at the back up light switch are you?
Old Oct 27, 2011 | 12:32 AM
Reddak's Avatar
Reddak
It is a 98. The plug has two barrels on it. I'm guessing it is the back up light sensor you are talking anout
Old Oct 27, 2011 | 12:47 AM
dodgeramguy85's Avatar
dodgeramguy85
Yes the clutch safety switch is on the pedal. You just need to find the neutral safety switch wires and connect them.
