Power loss
Old Nov 18, 2011 | 10:58 PM
Ts610's Avatar
Ts610
Default Power loss
Had a thread going about TPS but I kinda got off topic and still need help with power loss. 3.9 4x4. At any speed I can floor the truck. I watch the RPMS climb but the truck slowly gains speed. There is no kick. It kicks in if the cruise is on and needs to accelerate. I have changed the plugs and TPS so far. Any other ideas?
Old Nov 19, 2011 | 08:12 AM
crateampsrock's Avatar
crateampsrock
transmission slipping?
Old Nov 19, 2011 | 10:15 AM
Ts610's Avatar
Ts610
No. It is shifting much better since the TPS has been replaced. The strange thing is if I have the crusie set and it needs to speed up to stay at the correct speed it kicks in just like it should when I push on the gas.
Old Nov 20, 2011 | 02:26 AM
chrisy1961's Avatar
chrisy1961
My 3.9 was a dog when I bought it. I changed the plugs and wires and it got better. I changed the dist. cap and rotor and it got even better yet. I changed the Map Sensor about 6 weeks ago and now it runs like a champ. I have 178,000+ miles on my truck and it runs great. There are some threads on here about the map sensors. It was about $85 for the map sensor but it made a huge diffence in the way my truck runs.
Old Nov 20, 2011 | 09:07 AM
Ts610's Avatar
Ts610
I will look into that ty. I picked up a service manual for the truck so should tell me how to test it I hope.
Old Dec 1, 2011 | 07:07 AM
Ts610's Avatar
Ts610
Ok could use some more advice on this. Replacing parts and not getting results. So far I have replaced the TPS, cap and rotor, PCV, and spark plugs. Last night I was going up a pretty steep hill and I wasn't sure I was going to make it up. I know this motor has more I just can't find it. If you guys have more suggestions I would appreciate them. The snow will be flying soon and I am concerned that if I need the power it won't be there.
Old Dec 1, 2011 | 11:20 AM
Ts610's Avatar
Ts610
I am beginning to think I should change the spark wires out. From what I am reading the signs of bad wires can cause this symptom when a heavy load is applied. Runs great at slow speeds but when I get on it, it lags. Also I do notice a jerking feeling at higher speeds which would do the same thing.
Old Dec 1, 2011 | 12:22 PM
01SilverCC's Avatar
01SilverCC
The problem may be the plug wires, especially if they are old or even OEM. The problem could also be the Manifold Absolute Pressure (MAP) sensor. There is a long but very informative post about the MAP sensor and power loss here:
https://dodgeforum.com/forum/2nd-gen...er-solved.html
That post has a lot of good info in it. It may help you fix your truck.
Jimmy
Old Dec 2, 2011 | 07:59 AM
Ts610's Avatar
Ts610
I am going to try the wires first since they are cheaper than the MAP sensor. I have the service manual so I believe I will try to figure out the test procedure for the MAP sensor before buying. I also spoke to a friend who is a mechanic and huge Dodge truck fan and he said check the CAT and it could also be the lockout on the transmission. I checked the tailpipe yesterday and I felt what I believe to be enough pressure coming out and it felt pretty warm. Think I will take my infared thermometer and check the temp before and after the CAT also. I have got to get this fixed soon.
Old Dec 2, 2011 | 01:59 PM
Ts610's Avatar
Ts610
OK changed the wires. Also went to clean the IAC and well that didn't go so well. I put it back on and it malfunctioned so just went and bought a new one. Truck has even more power now but not all so.... I am down the MAP sensor and Governor pressure sensor and solenoid to look at. I am leaning toward the governor pressure sensor and solenoid simply because the truck feels like it kicking into a higher gear and the hard shift is still present. From what I am reading this may have something to do with the lockout. I am not aware of how this works.
I also took a look at the TV cable and it seems aweful loose but I am not sure how loose it should be. This is one of those fixes I am alittle leary on.
