Dodge Dakota transmission
Old Nov 28, 2011 | 10:25 PM
New 2 Dodge's Avatar
New 2 Dodge
if you need anything or have questions, let me know.
http://www.dakota-durango.com/forum/...90#post2876190
Old Nov 29, 2011 | 07:32 AM
dusty123's Avatar
dusty123
thanks
Old Nov 29, 2011 | 07:41 AM
New 2 Dodge
Dusty,
I had the same vibration - starting at 40mph - didn't matter how hard I was on the pedal. Again, Change the u joints - if nothing else - you will have new u joints at a low cost of under $30.00
The stalling issue, hmmm - no codes? Could be a sensor or bad ground connection. I can't offer any advice on that. I am slowly starting to replace sensors - many will say I am wasting my money but I can either pay minimum $100.00 for a diagnostic from the dealer with no guarantees or I can spend $100.00 and replace 2- 3 sensors that have about 110,000 miles on them...
As for the gas mileage - dude - I get 10mpg. Don't complain about 16 - it ain't no civic!
Keep posting, let us know how you make out.
Old Nov 30, 2011 | 07:28 AM
stonemaster's Avatar
stonemaster
+1 on the MPG but 10 ??? the V6 is rated at 15 mpg, I get about 16 in mine
New 2 u said u inspected the u joints with the drive shaft in the vehicle and didnt see anything, what procedure did u use ?? my mechanic buddy around the corner looked at mine and didnt see anything, he said he was looking for rust coming out of the caps
Old Nov 30, 2011 | 07:55 AM
New 2 Dodge
I did a visual inspection underneath the truck and tried turning the shaft, nad moving the joint from side to side looking for play but everything seemed tight. I mentioned it to my mechanic and he said that the best way to know is to drop the drive shaft and move the joints. If they are tight, they could be dried up inside. Sure enough when I pulled the driveshaft out, there was one bearing cap that had no needles left in and dryer than a boot. It was only after I had the shaft off that i could see the play in that joint.
Old Nov 30, 2011 | 10:24 PM
stonemaster
much appreciated bud, I'll update in a few days when i get a chance to check it out
Old Jan 9, 2012 | 09:13 PM
dusty123's Avatar
dusty123
thanks
Old Jan 12, 2012 | 02:20 AM
sl2racer's Avatar
sl2racer
i always try the cheaper fixes first. i figure worst case i have new stuff. and i have replacements should i need them since it wasn't the problem.
