Rattle, Rattle, Tick, Tick.........HELP!!
Old Nov 26, 2011 | 09:25 AM
milo09's Avatar
milo09
Default Rattle, Rattle, Tick, Tick.........HELP!!
99 Dakota 3.9 - I have a terrible rattle,tick when driving the truck. I don't have the noise in park but only driving?? It is coming from drivers side top end. Is there a way to test the truck under "load" without driving it?
Old Nov 26, 2011 | 11:47 AM
crateampsrock's Avatar
crateampsrock
uh ya... hold your foot on the brake while in drive and give it a little gas... Check for a broken exhaust stud.
Old Nov 26, 2011 | 11:50 AM
1986JEEP's Avatar
1986JEEP
If it is a 4x4 you could putt the t-case in neutral then you can putt it in gear eith out it moving. But their in not much load on the motor.
Old Nov 26, 2011 | 05:00 PM
crateampsrock
doesnt matter if the transfer case is in gear or not... The brakes will win the battle...every time...
Old Nov 26, 2011 | 05:14 PM
zanethan's Avatar
zanethan
Sound's like an exhaust leak. You might be chasing that one down for yearrrsssssssssssssssssssss. I had one in mine and could never get rid of it haha.
Old Nov 26, 2011 | 07:51 PM
milo09's Avatar
milo09
Found one of my exhaust manifold bolts broke off. I guess I'll try and drill it out tomorrow - Should be a great time : (
Old Nov 26, 2011 | 11:32 PM
Brian_'s Avatar
Brian_
milo, ive been having the same issue with my rig. i think i traced mine to the cat itself producing the nioise.
Old Nov 27, 2011 | 02:16 PM
milo09's Avatar
milo09
Angry Tick Tick - Leak!!
Guys!! I $#%@ up BIG TIME!!! Drilled a bit too far in removing the bolt and got antifreeze coming out. It's dripping out but man did I mess up!!!
Any thoughts? I have another head I could replace with but really didn't want to take the top end of my engine off.
It's a GREAT DAY!!!
Old Nov 27, 2011 | 04:06 PM
dolittle's Avatar
dolittle
When you reinstall the bolt, seal it with red lock tight it should seal the antifreeze leak.
Red is a high temp and it may work. You may have problems removing the bolt next time tho.
Old Nov 27, 2011 | 08:25 PM
milo09's Avatar
milo09
I'm going to give the lock tight a try tomorrow. Have I caused any long term damage?
