cv axle removal?
Old Nov 30, 2011 | 05:57 PM
thp803's Avatar
thp803
Default cv axle removal?
i have an 02 4x4 with a bad cv axle on the drivers side. i have looked in the search section and have looked on youtube and cant seem to find the information i am needing. i have everything off except the inner "cup" for lack of a better word. i cant get it to slide off of or out of the differential. any ideas on how to remove this? apparently some bolt on and some slide on and mine slides on.
Old Nov 30, 2011 | 08:35 PM
EricBing's Avatar
EricBing
Have an 02 as well.. had to take it to shop..couldn't get it to pop off, when the seals(o-ring) cracks it lets moisture in and allows a lil bit of rust in.. At budget tire the guy used an impact wrench with a pickle fork attachment, He said it was hard as well.. I got one off couldn't get 2nd one, come to think of it; drivers side wouldn't come off either..If ya can get it up high enough a pickle fork with an extension bar, and alot of cussing..wish ya luck< haynes manual has a detailed removal procedure as well
Old Nov 30, 2011 | 10:05 PM
thp803's Avatar
thp803
thanks for the reply. i have a good selection of air tools, i just wanted to get some direction before going wild. i guess it will come off as a whole or in pieces but it will come off. lol
Old Nov 30, 2011 | 10:54 PM
URBANRDNECK's Avatar
URBANRDNECK
You should let us know how this goes. I have to do the same thing but its on my pass. side
Old Nov 30, 2011 | 11:19 PM
thp803's Avatar
thp803
will def. post the out come and what worked or didn't...
Old Dec 2, 2011 | 01:34 AM
thp803's Avatar
thp803
This is where I was stuck yesterday. IMAG0108.jpg. I finished up this evening. I ended up using a 2.5 lb. hammer and a long ball joint separator. IMAG0109.jpg
i put the ends of the ball joint tool on the back side of the cup ( not between the cup and diff. housing ) and hit it about 3 times and it came off and landed on the floor. As you can see, there is alot of crud in there and the shaft looked the same.
I cleaned and greased the splines before putting the new shaft on and also put a new seal on. I ended up having to go to the Dodge dealer for the axle seal. I tried the chain parts stores ( AutoZone, Advance, etc...) and they did not carry it. Napa and Car Quest had to order it but it would be in next day. Just some fyi for the seal.
Old Dec 2, 2011 | 08:57 AM
URBANRDNECK
Thanks that is great to know! I will be sure to stop at napa today as I wanna try to get this done on saturday
Old Dec 2, 2011 | 11:49 AM
thp803's Avatar
thp803
Glad to be of some help. The seal from the dealer was $11 and $8 from the parts store. You will need the v.i.n. if you go to the dealer. He said there were 3 diff. Size axles used on the truck.
Old Dec 2, 2011 | 03:00 PM
URBANRDNECK
did you get it same day at the dealer or did you have wait?
Old Dec 5, 2011 | 01:18 AM
thp803's Avatar
thp803
sorry for the delay in getting back with you. they had it on the shelf.
