upper control arm bushings
Old Dec 9, 2011 | 12:36 PM
98DAKAZ's Avatar
98DAKAZ
Default confused
The state told you that you must fix these things or a shop told you this the state you live in can do that?
Or is it the state told you one or two things to fix then a shop told you the other things to fix.
Can you be clear on exactly what the state want fixed?
Old Dec 9, 2011 | 01:22 PM
mgaither0's Avatar
mgaither0
I had to do a state inspection since I bought a used vehicle. When I had it inspected at a shop for the state inspection, the shop made a list of all the **** that failed. On the list was the upper control arm bushings. They said I could replace the bushings because the arm wasnt bad.
Old Dec 9, 2011 | 02:07 PM
98DAKAZ's Avatar
98DAKAZ
Default Do you have to do all these
Do you have to do all these or are some your choice?
Can you take it to a second shop for a second opinion?
I dont know your state regulations living in Arizona because they dont do that in AZ you buy a used car thats it other than licence plate tags and smog check you are not forced to fix all needed things that sounds like an F**d state to live in.
