upper control arm bushings
Old Dec 7, 2011 | 11:40 PM
mgaither0's Avatar
mgaither0
Default upper control arm bushings
well from what I've read it looks like they have to be pressed out at a shop in order for me to get them out is this correct or is there anyway to do this at home? If I do need to press them any idea what a decent rate to have this done would be?
Old Dec 8, 2011 | 08:04 AM
Ts610's Avatar
Ts610
From what I am seeing the bushings can be replaced without replacing the whole control arm. I have seen where people torch the old ones out. I have also heard of people freezing the new ones so they shrink before installation. I may be wrong on this so hopefully others chime in if so.
Old Dec 8, 2011 | 09:26 AM
98DAKAZ's Avatar
98DAKAZ
Default well
I have not done this yet but my understanding is all you need to remove them is rent a tool from autozone that can remove them they will know what you need.
Old Dec 8, 2011 | 11:03 AM
bpark8824's Avatar
bpark8824
Yeah, they need to be pressed out and the new ones be pressed in. You may find ways of getting the old ones but good luck getting the new ones in. It's worth it to have them pressed. NAPA will do it if you bring them the control arm for like $5 a bushing. We have a press at work so I did it there.
Old Dec 8, 2011 | 11:32 AM
98DAKAZ's Avatar
98DAKAZ
Question Ok a question
Ok a question
Do you need those bushings replaced make sure because they are a major pain in the *** to replace if they are cracked a little bit they are still probably just fine those bushings are two inches deep of rubber.
You only need to replace them if they are sloppy or you can see that they are moving around.
All to many people just think they need to replace them they look old and cracked but those things are very thick and durable.
Old Dec 8, 2011 | 12:19 PM
bpark8824's Avatar
bpark8824
I replaced mine because they squeaked terribly. Spraying them would stop it for a day or two but they really need to changed.
Old Dec 8, 2011 | 12:33 PM
98DAKAZ's Avatar
98DAKAZ
Default you had a bad one
Sounds like you had a bad one all right but beware all to many auto shops will tell you they are bad why they want your money it’s a con job I went to a shop to get an alignment and they wouldn’t do it saying my bushings were bad what a joke I just replaced all my ball joints and installed new coil springs so I know they were not bad.
So beware of shops claiming you need new bushings
Old Dec 8, 2011 | 12:38 PM
bpark8824's Avatar
bpark8824
That's true with anything though. You to have a water pump replaced and they say you need a new fuel... completely unrelated but a lot people don't know that so they fall for it.
I have a business ethics class as an elective and we went over a case were Sears received bonuses for the amount of work they got. The gov't sent in 300 people to have brakes replaced all over the country and 80% of them were over charged and told they must replace other parts even though the people taking them to the shop knew the car only needed brakes. People we being changed an extra $200-$300 on AVERAGE. Sears got caught because they're a big company. All the little shops won't ever get caught because nobody is watching them.
Sorry to digress from the OP, don't want to jack your thread.
Old Dec 8, 2011 | 12:56 PM
98DAKAZ's Avatar
98DAKAZ
Angry woman get burned the most
Woman get burned the most they have no clue.
Like this I got new quality tires and alum. Rims cost $350 this was in 1985 thus the great price a gal I knew said hay I just did that why was it so cheap she said I just paid $750 I said WHAT? what did you buy gold plated rims?
She got ripped off about $300 she didn’t know woman just don’t know they get taken probably 80% of the time.
Old Dec 9, 2011 | 03:20 AM
mgaither0's Avatar
mgaither0
The only reason I was replacing them is because my truck failed state inspection and the shop gave me a list of $4,500 in repairs I needed to pass state inspection. So the last few days I've been fixing the stuff.
