Headliner Problems
I'm honestly thinking about ripping my console out.. but.. it has two lights my wife uses quite a bit.. (Thinks about it..... thinks about it.. all well she dont need them) ha ha..
Just an idea.. Idk yet.. cant really put a Cobra 29LTD Classic in that i want where i want cus the 4x4 shifter.. but I could fit one of those tiny black ones..
$150-$200 is what i normally charge up here in WI.(GO PACK) i would (up here) recover it for $100 if you remove and install it. (i know you dont have the time) temporary staples do more harm than good. find a trim shop, have them color match it, then pull the hanging stuff off to get it out of your way.
This is the OEM Dodge model, though. The RB1. If I'm not mistaken, it has an antena that is hard-wired and goes through the roof...
Okay, I've got good news and bad news...
Good news: The headliner is out. Bad news: It didn't go so smooth...
First, I managed to tear the material between the front of the liner and the light. I didn't even have time to flinch, it just happened. FYI for all you manual trans dakota guys: the shift **** turns into a perfect headliner ripper, once the liner is off the roof.
Also, neither of the retainers for the visors survived. I have no idea how those were supposed to come out, but they ended up coming out in pieces.
Aside from that, everything went fine!
This would of helped you with pic's how to.
http://www.dakota-durango.com/forum/showthread.php?t=96058
Thanks though. It will be a great help for putting them back on.
Out of curiosity, are those the "Visor supports"? I was looking at the dodge parts website and that's what I think those were called. They're only $9...
yes supports not sure this link will work but look here https://www.dodgeparts.com/oe_parts_catalog.html
yes supports not sure this link will work but look here [/SIZE]https://www.dodgeparts.com/oe_parts_catalog.html[/SIZE]
They also have OEM replacement headliners. They were somewhere on the order of $350, IIRC.
