Please Help !!! I am Stumped
Old Dec 22, 2011 | 05:23 PM
adrenalinejunki's Avatar
adrenalinejunki
Exclamation Please Help !!! I am Stumped
Hey guys i need your help please any advice....
I have a 97 Dakota 4X4 5.2
2 days ago it was shifting slugish from 2nd to 3rd and so today i was driving and the truck was starting out in 2nd and so i took it apart and replaced the Governor Pressure solenoid and the Governor pressure thansducer with fluid flush and new trans pan filter and gasket and the truck shifts a little better but still no 1st gear....
I have dumped 300 into it so far and it figures this would happen 2 days prior to christmas...
should i replace the overdrive solenoid?????
I did replace the TPS Sensor a few months ago could that be the problem??
Old Dec 22, 2011 | 10:32 PM
master tech's Avatar
master tech
Site Moderator & Tech
If you were to put the shift lever into low gear range and start from a stop, do you have 1st gear? If you don't, Then its time to check line pressure and see what you have. I will post the information in the DIY and here as well. How was the fluid condition before you change it? And did you adjust any bands?
Old Dec 22, 2011 | 11:48 PM
master tech
HYDRAULIC PRESSURE TEST
Hydraulic test pressures range from a low of one psi (6.895 kPa) governor pressure, to 300 psi (2068 kPa) at the rear servo pressure port in reverse.
An accurate tachometer and pressure test gauges are required. Test Gauge C-3292 has a 100 psi range and is used at the accumulator, governor, and front servo ports. Test Gauge C-3293-SP has a 300 psi range and is used at the rear servo and overdrive ports where pressures exceed 100 psi.
Pressure Test Port Locations
Test ports are located at both sides of the transmission case
Line pressure is checked at the accumulator port on the right side of the case. The front servo pressure port is at the right side of the case just behind the filler tube opening.
The rear servo and governor pressure ports are at the right rear of the transmission case. The overdrive clutch pressure port is at the left rear of the case.
Test One - Transmission In Manual Low
NOTE: This test checks pump output, pressure regulation, and condition of the rear clutch and servo circuit. Both test gauges are required for this test.
Connect tachometer to engine. Position tachometer so it can be observed from driver seat if helper will be operating engine. Raise vehicle on hoist that will allow rear wheels to rotate freely.
Connect 100 psi Gauge C-3292 to accumulator port. Then connect 300 psi Gauge C-3293-SP to rear servo port.
Disconnect throttle and gearshift cables from levers on transmission valve body manual shaft.
Have helper start and run engine at 1000 rpm.
Move transmission shift lever fully forward into 1 range.
Gradually move transmission throttle lever from full forward to full rearward position and note pressures on both gauges:
Line pressure at accumulator port should be 54-60 psi (372-414 kPa) with throttle lever forward and gradually increase to 90-96 psi (621-662 kPa) as throttle lever is moved rearward.
Rear servo pressure should be same as line pressure within 3 psi (20.68 kPa)
Test Two - Transmission In 2 Range
NOTE: This test checks pump output, line pressure and pressure regulation. Use 100 psi Test Gauge C-3292 for this test.
Leave vehicle in place on hoist and leave Test Gauge C-3292 connected to accumulator port.
Move transmission shift lever one detent rearward from full forward position. This is 2 range.
Move transmission throttle lever from full forward to full rearward position and read pressure on gauge.
Line pressure should be 54-60 psi (372-414 kPa) with throttle lever forward and gradually increase to 90-96 psi (621-662 kPa) as lever is moved rearward.
Test Three - Transmission In D Range Third Gear
NOTE: This test checks pressure regulation and condition of the clutch circuits. Both test gauges are required for this test.
Turn OD switch off.
Leave vehicle on hoist and leave Gauge C-3292 in place at accumulator port.
Move Gauge C-3293-SP over to front servo port for this test.
Have helper start and run engine at 1600 rpm for this test.
Move transmission shift lever two detents rearward from full forward position. This is D range.
Read pressures on both gauges as transmission throttle lever is gradually moved from full forward to full rearward position:
Line pressure at accumulator in D range third gear, should be 54-60 psi (372-414 kPa) with throttle lever forward and increase as lever is moved rearward.
Front servo pressure in D range third gear, should be within 3 psi (21 kPa) of line pressure up to kickdown point.
Test Four - Transmission In Reverse
NOTE: This test checks pump output, pressure regulation and the front clutch and rear servo circuits. Use 300 psi Test Gauge C-3293-SP for this test.
Leave vehicle on hoist and leave gauge C3292 in place at accumulator port.
Move 300 psi Gauge C-3293-SP back to rear servo port.
Have helper start and run engine at 1600 rpm for test.
Move transmission shift lever four detents rearward from full forward position. This is Reverse range.
Move transmission throttle lever fully forward then fully rearward and note reading at Gauge C-3293-SP.
Pressure should be 145 - 175 psi (1000-1207 kPa) with throttle lever forward and increase to 230 - 280 psi (1586-1931 kPa) as lever is gradually moved rearward.
Test Five - Governor Pressure
NOTE: This test checks governor operation by measuring governor pressure response to changes in vehicle speed. It is usually not necessary to check governor operation unless shift speeds are incorrect or if the transmission will not downshift. The test should be performed on the road or on a hoist that will allow the rear wheels to rotate freely.
Move 100 psi Test Gauge C-3292 to governor pressure port.
Have helper start and run engine at curb idle speed. Then firmly apply service brakes so wheels will not rotate.
Note governor pressure:
Governor pressure should be no more than 20.6 kPa (3 psi) at curb idle speed and wheels not rotating.
If pressure exceeds 20.6 kPa (3 psi), a fault exists in governor pressure control system.
Release brakes, slowly increase engine speed, and observe speedometer and pressure test gauge (do not exceed 30 mph on speedometer) Governor pressure should increase in proportion to vehicle speed. Or approximately 6.89 kPa (1 psi) for every 1 mph.
Governor pressure rise should be smooth and drop back to no more than 20.6 kPa (3 psi), after engine returns to curb idle and brakes are applied to prevent wheels from rotating.
Compare results of pressure test with analysis chart.
Test Six - Transmission In Overdrive Fourth Gear
NOTE: This test checks line pressure at the overdrive clutch in fourth gear range. Use 300 psi Test Gauge C-3292 for this test. The test should be performed on the road or on a chassis dyno.
Remove tachometer; it is not needed for this test.
Move 300 psi Gauge to overdrive clutch pressure test port. Then remove other gauge and reinstall test port plug.
Lower vehicle.
Turn OD switch on.
Secure test gauge so it can be viewed from drivers seat.
Start engine and shift into D range.
Increase vehicle speed gradually until 3-4 shift occurs and note gauge pressure.
Pressure should be 469-496 kPa (68-72 psi) with closed throttle and increase to 620-827 kPa (90-120 psi) at 1/2 to 3/4 throttle. Note that pressure can increase to around 896 kPa (130 psi) at full throttle.
Return to shop or move vehicle off chassis dyno.
Old Dec 25, 2011 | 01:05 AM
adrenalinejunki
Fluid wasnt burnt and pan had some shavings but no chunks. I havent adjusted any bands yet but i was planning on replacing the OD solenoid next due to the fact that i never was able to push the OD button and turn it on or off... If i put the truck in low 1 it doesnt move. It almost feels like it fighting for the gear selection
Old Dec 26, 2011 | 02:59 PM
adrenalinejunki
just found the 8 pin connector is cracked and needs to be replaced. where can i purvchase the connector so i can rewire it????
Old Dec 26, 2011 | 03:23 PM
JBs DAK's Avatar
JBs DAK
bone yard would be my best bet or,.. New from,.. You guessed it,.. THE - STEALER-SHIP.
Sad to say.
Old Dec 26, 2011 | 04:20 PM
ahsnowlover's Avatar
ahsnowlover
Sometimes NAPA can match connectors
