which should i use????
Old Dec 27, 2011 | 07:13 PM
  #21
Johnn123's Avatar
Johnn123
I've always just used Mopar 5w-30 in mine, never has an issue in the cold.
Old Dec 29, 2011 | 01:33 PM
  #22
BLSHOG10's Avatar
BLSHOG10
thanks for all the input guys ill probably just stick with what has worked so far but if i do try the synthetic ill let all you guys know what i think about it
Old Dec 29, 2011 | 03:11 PM
  #23
98DAKAZ's Avatar
98DAKAZ
Lightbulb final points synthetic oils
The things that get over looked about synthetic oils is.
1 they take the heat and cold better than regular oil.
2 synthetic oils also keep your engine clean no sludge.
3 synthetic oils dont brake down like regular oil.
4 synthetic oils are proven friction reducers.
But most folks only look at one thing how $$$ synthetic oil is so they avoid them.
They would rather spend big $$$$ for some fuzzy dice for thier window instead.
Old Dec 29, 2011 | 05:45 PM
  #24
bpark8824's Avatar
bpark8824
Synthetic oil keeps your engine CLEANER (slightly) than regular oil. You make it sound like its spotless with synthetic and filled with sludge on conventional oil. They can last longer. Usually in our trucks, the synthetic doesn't have quite the pay off (IMO) that it would in different vehicles. If you use conventional and change it every 3-5k miles, you will never have a problem. Either way some sludge and carbon will build up over time. It's going to happen one way or another.
Old Dec 29, 2011 | 06:08 PM
  #25
2daks's Avatar
2daks
+1 on changing at the recommended intervals. I use whatever is a good price at the time. In my 09 Ram with 17k miles on it I used a cheapy filter and cheap oil. Next change I bought a mopar filter from Wally world and Quaker State synthetic blend,( 7 Quarts for the beast). Mostly because price was only a few bucks more and I slept a wee bit better.
On the 97 Dakota.... High milage oil and whatever filter.
Point is whatever makes you feel OK, just change it on time and if it makes everyone happy use a Synthetic blend.
Old Dec 29, 2011 | 06:16 PM
  #26
98DAKAZ's Avatar
98DAKAZ
Default the past is the past
The past is the past
Synthetic oil has been proven over and over to beat conventional oil hands down. So why???
http://www.synthetic-motor-oil-chang...-to-synthetic/
Old Dec 29, 2011 | 06:30 PM
  #27
dodgeramguy85's Avatar
dodgeramguy85
I use syn blend and change mine every 3,500 miles. I pay 22 for oil and a filter so its not that bad every 3 months. My dad does his syn every 11k
