P/S whine will not go away!!!!!
Old Feb 21, 2013 | 04:05 PM
  #31
98DAKAZ's Avatar
98DAKAZ
post a vid of this mystery noise lets hear it lets hear this amazing noise that has you so hot.
you have had experts look at it us on the forum try to help but claim your Dakota sounds like hell... lets hear it
If you hate it get rid of it
Old Feb 24, 2013 | 02:15 PM
  #32
Dakmm's Avatar
Dakmm
Can't the truck is gone, was swallowed up by 8' of saltwater from the surge of Sandy.....along with my house, garage and every tool I owned.
I did have a video of it that I never posted, but it was on the computer that got swallowed also, I might have a copy somewhere but I don't know where anything is anymore, at this point.
If I ever find it again maybe I'll post it, although it's not at the top of my priority list at the moment and unless I end up with another Dak that has a whine then it probably won't be.
Just wanted anyone that was doing a Search to know that in my case the problem WAS the pump....and nothing else. Sometimes you just can't stop the whine when the pumps are designed poorly.
Old Feb 25, 2013 | 09:59 AM
  #33
eisej's Avatar
eisej
Default Wrong pump / Wrong fluid
I went back to carquest to get a new pump. They were ready to give me an identical pump when one of the other guys came up and said that the pump they gave me was the wrong pump. I'm not sure how their system brought up the wrong pump but it did. The right pump was identical on the exterior but the internals and the volume it could push was different.
This was also very interesting. The Cordone website that they showed me at carquest had a TSB for the pump. It said that the pump should not be filled with power steering fluid but instead with ATF+4 completely. How F'd up is that?
None the less I put the new pump on, filled it with ATF+4, and all is right with the world. No squeal, no locking, no foaming, and not to mention the overall sound with the hood open is quieter. I now can really notice the road noise from my tires which are in need of replacement.
Hope this helps someone.
Old Feb 25, 2013 | 10:09 AM
  #34
bwdakrt's Avatar
bwdakrt
It would be great if you were to post up the part # for the correct PS pump. May help someone out in the future.
Old Feb 25, 2013 | 12:44 PM
  #35
DakCC4x4's Avatar
DakCC4x4
I cant believe no one has tried to swap out the steering box for another model truck and get rid of the stock junk. If you could find a pump similar to one the Dak uses and swap it in. Seems more simple in theory i know but still.
Old Feb 25, 2013 | 01:40 PM
  #36
98DAKAZ's Avatar
98DAKAZ
Sorry to hear that Dakmm
Good luck getting things back together thats a shame did you save the tools, House and other stuff salt water is a nasty flood to deal with.
Im guessing the Dakota was totaled?
Old Feb 25, 2013 | 02:01 PM
  #37
bwdakrt's Avatar
bwdakrt
Nothing survives soaking in salt water. Eventually the rust and corrosion is going to destroy it.
Old Feb 25, 2013 | 02:20 PM
  #38
Robbadodge's Avatar
Robbadodge
Very sorry to hear. Good luck on the clean up and hope a rebuild is an option.
Robb
Old Feb 26, 2013 | 10:49 AM
  #39
eisej's Avatar
eisej
Dakkmm - Hope everything gets better for you. Sincerely.
I don't want anyone getting confused since the issue I had, even though it was similar, the problem was that the pump was wrong for my 2005 Ram 1500. So I'll post the part numbers in the 3rd Gen forum.
Old Mar 11, 2014 | 01:12 PM
  #40
twelsh's Avatar
twelsh
I had the same problem with that constant whinging noise. The screen in the reservoir was clogged.
