Strange whine under acceleration.
Old Jan 15, 2012 | 02:37 PM
Roogiee's Avatar
Roogiee
Default Strange whine under acceleration.
Hey guys, I've been lurking the forums for a while as I bought my first Dodge truck almost a year ago. I did a search on noises but I don't know if they fit my situation or not and I would appreciate your help.
The truck is an '04 4.7l 4x4 automatic, bone stock. I've noticed a whine around certain speeds that increases under acceleration. It SEEMS worse in the cold, it was -18 Celsius today (yay for Canadian winters). Regardless of whether the truck is warmed for 20 mins outside or started and driven from a heated underground garage the sound still occurs.
I've noticed it around 10 mph, 25 mph, and 50 mph. If the sound starts and I gun it a bit the sound sharply increases and sounds like its coming from the front end somewhere. EDIT: Internet research seems to indicate it comes from the rear end.
Let me know if there is any vital info I may be missing and thank you for any insight.
Old Jan 15, 2012 | 03:27 PM
MikeRWK's Avatar
MikeRWK
Maybe someone installed a supercharger without you knowing? :P Check all the clamps on the air intake and see if theyre tight and check to see the box is also tight. Start the truck, pop the hood and have someone see if they can find where its coming from, it could also be an exhaust leak.
Old Jan 15, 2012 | 07:27 PM
Roogiee's Avatar
Roogiee
I checked the airbox and it's fine, it only happens when driving. I did a little digging around the internet and someone uploaded a video that contained the same issue as mine:
http://youtu.be/u5Zf9yByjy4
Thats the noise I'm hearing.
EDIT: Did some more digging and found that most people that have a whining noise say it comes from the rear end. I'll open the rear diff at some point and inspect everything but I'll have to wait till the shop space is available (living in a condo, the board doesn't like us working on vehicles). I could be wrong so if anyone has a similar experience please post!
Old Jan 17, 2012 | 08:49 AM
UWAdventurer's Avatar
UWAdventurer
Are you sure it is not coming from the transfer case? Mine whines.
Old Jan 17, 2012 | 08:56 PM
dodgeramguy85's Avatar
dodgeramguy85
I've never heard a rear end sound like that. They are more low growling noises. I would start with idle pulley and the tensioner. Check to make sure all your other pulleys are tight and spin freely.
Old Jan 17, 2012 | 09:01 PM
Roogiee's Avatar
Roogiee
I talked to a mechanic friend of mine and that seems to be his conclusion as well. I'll take it into his shop on the weekend and check these.
I should have taken automotive instead of carpentry but what is a man to do?
Thanks for the suggestions all.
Old Jan 17, 2012 | 09:33 PM
dodgeramguy85
I took automotive because growing up I learned a lot of carpentry from my dad so it was really the only thing I wanted to take lol Both parts are easy to change about 30min for both if your not familiar with doing it
