Calling 1997 to 2004 Daks with 35s
Old Jan 24, 2012 | 04:10 PM
Bertpod's Avatar
Bertpod
Question Calling 1997 to 2004 Daks with 35s
Im lookin at gettin a 97/04 Club/Extended Cab
V8 4x4 Dakota so Im lookin for a little FeedBack..
I know that most 4x4 Dakotas fit 31x10.5 Stock..
I wanna know if the T.Bars r Twisted n a 3" Body
Lift is Added will the Fenders HAPPILY clear 35s??
Most 35s arent True to size.. Knowin that BFG A/Ts
31x10.5 R 30.7" n 35x12.5 R 34.7" What Im thinkin
is that True 4" taller tires, n about 3.5 to 5 Total "
of Lift between Body Lift n T.Bar Crank should be
about the same as Stock Fender to Tire Clearance..
.............................Right??.............................
If any1 here of Pix of What I said can you post them
on this Tread for me?? Would be even Better if Club Cab..
That way I can Truley see what the Dak will look like...
Thanx,
Rob
Old Jan 24, 2012 | 07:03 PM
Xxaler's Avatar
Xxaler
Yes they'll clear with 100% cranked aftermarket torsion keys, blocks in the rear, and body lift.
But also, you'll go through CV shafts and tie rod inners and outters like they're nothing.
Old Jan 24, 2012 | 10:54 PM
dodgeramguy85's Avatar
dodgeramguy85
I think another member(blaze) has 35's. Either way it will clear but you might have to trim a little bit of your bumper. I know my 32's are close to my bumper.
Old Jan 25, 2012 | 02:55 AM
Bertpod's Avatar
Bertpod
Ur Dak Is Leveled N doesnt have a Body Lift With 32s?
Old Jan 25, 2012 | 07:50 AM
dodgeramguy85
Its just leveled you dont need a body lift to fit 32's
Old Jan 25, 2012 | 10:09 AM
DakCC4x4's Avatar
DakCC4x4
My 04 Dak is leveled with 285s on it. I did have to clearance the valance and inner fender a bit due to the lugs on the MTs combined with offroad usage. Some aftermarket wheels may help them fit a little better due to backspacing and such. Mine are on stock wheels.
Old Jan 25, 2012 | 12:15 PM
ryan_brown33's Avatar
ryan_brown33
by leveled do you mean cranked torsion bars? i want to put 285s on mine and i have aftermarket wheels with a 12mm offset vs the 25mm offset on the stock wheels so i know that will help some. plus i am not afraid to cut a little bit of plastic
Old Jan 25, 2012 | 02:10 PM
hanleysh's Avatar
hanleysh
I'm running 315/75/16's(35's) with re-indexed keys(maxed minus one turn) add-a-leafs in the back and a 3" body lift ill try to post up a pic when I'm done with work for the day. Only rubbing issues I have is on the frame. Could be easily solved with 1" wheel spacers or diff wheels
Old Jan 25, 2012 | 04:34 PM
DakCC4x4's Avatar
DakCC4x4
Yeah just got the tbars cranked a little. Plus i have the extra weight of a winch on the front but it stays level.
Old Jan 25, 2012 | 07:41 PM
ahsnowlover's Avatar
ahsnowlover
I got 2" of lift out of my factory tbarsbars
