98 Dakota CTM problems
Old Jan 26, 2012 | 12:55 PM
trainzzz's Avatar
trainzzz
Default 98 Dakota CTM problems
Looking for help on how to test the CTM on the 98 dakota. I was also told it was behind the wall on drivers side. Didn't see it although I hear clicking behind dash on passenger side.
Old Jan 26, 2012 | 01:14 PM
00DakDan's Avatar
00DakDan
Section Moderator
It's behind the passenger side kick panel.
What is the issue? There is no "self test."
Old Jan 26, 2012 | 02:27 PM
trainzzz's Avatar
trainzzz
Wow, Just found it. It seems to be hung up on something at the top. I can't see up there to see if there is another plug. I have unpluged the two at the bottom.
To give you a little back ground. When I picked up my truck having the motor rebuilt and when I got home, my horn would blow like the alarm was going, my wipers would start working by themselves, I have no reverse lights even after changeing the bulbs. But I could deal with that by unpluging the horns. lol But now she won't start. I beleive while my motor was being rebuilt, someone triied to steal it due to my rear veiw mirror was missing. I didn't have this problem before. What a mess.
Old Jan 26, 2012 | 07:00 PM
00DakDan's Avatar
00DakDan
Section Moderator
Do you have factory security?
Old Jan 26, 2012 | 09:16 PM
trainzzz's Avatar
trainzzz
Yes. I see the chrystler emblem on the CTM. It won't come out though. It seems to be stuck on something. I may have forgotten to mention that my keyless remote is not working as well. When my key touches the last slot, thats when the horn starts to blow.
Old Jan 26, 2012 | 10:13 PM
00DakDan's Avatar
00DakDan
Section Moderator
If it's like an '00 then you have to take off the glove box. The CTM and its bracket come out together through that opening.
Do you have any CEL codes?
Old Jan 26, 2012 | 11:09 PM
trainzzz's Avatar
trainzzz
I took out the glove box and there is no access to the CTM. I can't even touch it though the glove box. I can wiggel the CTM around but it is catch on something. I'm going to try again Friday. Does the CTM sound like the problem to you.
Old Jan 27, 2012 | 10:52 AM
00DakDan's Avatar
00DakDan
Section Moderator
Part of it sounds more like a bad ground. The backup lights and wipers share a ground, near the battery. Might have happened while the motor was pulled.
The horn sounding does act like the security system. Is the light on the dash on?
Old Jan 27, 2012 | 01:40 PM
trainzzz's Avatar
trainzzz
No alarm light is showing on the dash. Going out now to check some more.
