Pinging when on the throttle
Old Feb 3, 2012 | 11:24 PM
02Dakota4.7's Avatar
02Dakota4.7
Default Pinging when on the throttle
I have a 2002 Dakota 4.7 i just recently bought a superchips flashpaq. I had a slight pinging before with 87 octane. So i started running 91 or 93 octane and dont have a problem. Now when i Set the tuner to 91 performance or towing mode it Pings bad. I was wondering if any one could tell me how to fix the problem?
Old Feb 4, 2012 | 08:30 AM
02Dakota4.7
Angry
does anyone have a clue whats happening??? Truck is really pissing me off
Old Feb 4, 2012 | 10:23 AM
00DakDan's Avatar
00DakDan
Section Moderator
Here's some ideas:
Possibly the wrong heat range on the spark plugs. What are you running?
Carbon buildup in the heads.
Air/Fuel ratio to lean.
Old Feb 4, 2012 | 10:34 AM
02Dakota4.7
They are the factory plugs. truck has 120K. would a set of
new plugs posibly help?
Old Feb 4, 2012 | 11:00 AM
02Dakota4.7
I actually just pulled out the plugs and they look somewhat new. they are champion 3318. the plugs do look alittle white on the lean side. is there some kind of adjustment? or are they the wrong plugs??
Old Feb 4, 2012 | 12:23 PM
00DakDan's Avatar
00DakDan
Section Moderator
What do you mean factory? As in the original set?
You could throw in a new set, 3318 is fine. Brown or light gray is normal. There is no adjustment, the PCM handles the A/F ratio.
Old Mar 27, 2012 | 01:21 AM
tnvols123's Avatar
tnvols123
If you are losing oil as well, have your plenum gasket checked
Old Mar 27, 2012 | 09:41 AM
00DakDan's Avatar
00DakDan
Section Moderator
There's no plenum gasket in the 4.7.
Old Mar 27, 2012 | 01:22 PM
moe7404's Avatar
moe7404
you need a plug at lest 1 heat rang colder 2 colder is better. also a plug with the spark gap closer to the base, its like turning the timing back. and opening the the gap .005 in will make the heat range took like it is 1/4 to 1/2 hotter.
Old Mar 28, 2012 | 05:54 AM
DakinUK's Avatar
DakinUK
I used to use a Superchips 3715 (I think!) programmer on my 4.7 and it also made mine ping. I thought it was because there's a difference between how they measure the Octane rating over here. I had to run mine on Super Unleaded (most expensive grade here) and it STILL occasionally pinged, so had to use Octane booster.
I think they run too much advance in their settings. I now have a SCT tuner with a Hemifever standard tune, which has been slightly modified for the fuel over here. definitely the way to go!
By the way, the 4.7 doesn't have a plenum gasket, just a plastic inlet manifold, although I have seen one that had got so hot that the plastic had started to deform.
