Heat doesn't get hot
Old Feb 5, 2012 | 09:31 PM
Ziegled1's Avatar
Ziegled1
Question Heat doesn't get hot
What would make my Dakota not blow hot air? I flushed the radiator and refilled it. The Tempature gauge is moving and getting in the right area. But the air is just warm coming out the vents.
Old Feb 5, 2012 | 09:57 PM
00DakDan's Avatar
00DakDan
Section Moderator
It's probably a dirty or partially clogged heater core.
Try backflushing it, it usually works.
Old Feb 5, 2012 | 11:53 PM
aircruiser's Avatar
aircruiser
This, and make sure all the vaccum lines are properly connected. I wasn't getting heat in my Jeep grand cherokee and it was a vac line that had popped off under the hood.
Old Feb 6, 2012 | 05:27 AM
Rob2004's Avatar
Rob2004
Similar to the above post make sure the valve is opening that allows the water to flow.
Old Feb 6, 2012 | 06:21 AM
bwdakrt's Avatar
bwdakrt
There is no valve that allows the water to flow thru the heater core. The heat inside the cab is controlled by the blend door.
Remove the 2 heater hoses from the intake manifold and the water pump. Using a water hose, force water into the end of one hose and then the other. Keep doing this back and forth flushing until the water runs clear. Reconnect the heater hoses, start the engine and allow it to come up to operating temp while topping off the coolant system with antifreeze and allowing all the air bubbles to work out of the system.
You'll be surprised at all the crud that comes out of the heater core and will really appreciate the new found heat inside the cab.
Old Feb 6, 2012 | 11:06 AM
aircruiser's Avatar
aircruiser
Yeah flushing the heater core helps a ton but I gotta say, I love your sig line haha
Old Feb 8, 2012 | 12:14 AM
Rob2004's Avatar
Rob2004
I forgot to preface it with "without looking at the manual". I was thinking of another vehicle with a valve and picturing a blend door on an older car.
