Headlight Assembly Screws
Old Feb 19, 2012 | 05:55 PM
Johnn123's Avatar
Johnn123
Default Headlight Assembly Screws
Hey all, I have a slight problem with my headlights. I bought 2 new bulbs a few days ago for my dakota because mine are nearly dead. I went today to go put them in but discovered that all the screws holding the assemblies in place are stripped.
What can I do to get these out?
Old Feb 19, 2012 | 06:06 PM
Rakaric's Avatar
Rakaric
Are you sure they are stripped, or are they torx head screws? I think the stock headlights come with torx head screws.
Old Feb 19, 2012 | 06:18 PM
Johnn123's Avatar
Johnn123
No they're stripped, I have torx head screw drivers and the only one that isn't stripped fits the torx head. The rest might as well just have holes punched in the head.
Old Feb 19, 2012 | 06:28 PM
Rakaric's Avatar
Rakaric
k, just checking. Not sure too much what you'll be able to fit in there to get those out. However, you probably still can change the light bulbs through the inside of the fender if you can fit through there.
Old Feb 19, 2012 | 06:31 PM
Johnn123's Avatar
Johnn123
Would I have to pull the plastic inside the wheel well out? I'm not sure where I can get in there from.
Old Feb 19, 2012 | 07:35 PM
Rakaric's Avatar
Rakaric
You can open up the hood, and there's a hole you can reach into if you follow the wire harness.
Old Feb 19, 2012 | 08:47 PM
98DAKAZ's Avatar
98DAKAZ
Default New screws
You should use some needle nose pliers and extract them then install new but I’m not sure where you get the screws?
Old Feb 19, 2012 | 09:18 PM
UWAdventurer's Avatar
UWAdventurer
I would try a hardware store for screws, as long as the threads are the same who cares about the type of head it has? Just make sure the head size will fit the room allowed for installation.
Old Feb 19, 2012 | 09:44 PM
MoparMan1991's Avatar
MoparMan1991
Come on folks! You can go to a Menards, Lowes, Home Depot, or any store like that and buy a stripped screw extraction kit.
Old Feb 19, 2012 | 09:57 PM
Brian_'s Avatar
Brian_
sawzall makes good work too! that is if you have new headlights to install like i did.
