Lift confusion
Old Mar 9, 2012 | 05:11 PM
dakotaguy1994's Avatar
dakotaguy1994
Default Lift confusion
I have a chance to get a deal on torsion keys real cheap but am a little confused on them.
i believe some say not to do it because stress on the front end.
are cranking the torsion bars only going to lift the front?
if anyone could just give me a good overview on cranking torsion bars and torsion keys id appreciate it.
thanks
Old Mar 9, 2012 | 05:27 PM
OSUBauer's Avatar
OSUBauer
I have read here that cranking the torsion bars will give approx 2" of lift. I don't know how it affects ride or stresses front end. I've never used the keys.
Old Mar 9, 2012 | 11:15 PM
dodgeramguy85's Avatar
dodgeramguy85
I have had my torsion bars cranked for over a year now. It lifted my front about 1.5 in I could of went more but I didnt want it higher than the rear. I personally think it handles way better than before and isnt much stiffer but thats just me
Old Mar 10, 2012 | 03:07 PM
dakotaguy1994
so basically the torsion bars are just to level out the front with the back correct?
i want to put on 33's so i was thinking of cranking them to be about even as you did than adding a 3 inch body lift...
Old Mar 10, 2012 | 04:55 PM
dodgeramguy85
With stock keys you will only gain so much, pretty much just leveling the front. But with cranked torsion bars you can fit 32's or with a 2in body lift and cranked bars you can fit 33's
Old Mar 11, 2012 | 11:15 AM
dakotaguy1994
sweet deal man thanks
Old Mar 12, 2012 | 07:08 AM
DakMan6704's Avatar
DakMan6704
Actually, you can only go up a set amount. I.e. where your upper arm hits the travel limit of your suspension. That being said, if your bars are 'tired', the re-indexing keys would be like putting a couple extra cranks on a clock spring, or window shade. basically giving you a new angle where the bolts start. I dont think they are really worth getting keys, but I'm not bottomed out on my adjusters either.
Old Mar 12, 2012 | 11:54 AM
MoparMan1991's Avatar
MoparMan1991
Getting new keys doesn't do anything for you. Just crank the T-Bars. I don't know how the Dakotas are set up but on the Durangos, we do 8 turns on both T bar bolts, and Chevy 2" lowering shackles for the rear leaf springs as out shackles are upside down to a chevy, thus lowering for them will lift for us.
