exhaust manifold removal
i have a question has anyone found any good sprays that can help loosen up the bolts on the exhaust manifold? cause i was going to change mine this past week and i noticed that the bolts were rusted to all hell. so i figured i would ask here before i tried to just crank them out.
as all ways my buds here have good ideas. but when you go back togather be sure to use anti-sieze on ALL theards, even on mating serfaces. when you tighten the bolts only tighten them to 75-80 % first, then after 6-8 heat cycles tighten the rest of the way.. i do mean ALL THREADS. after 15-20 years youll be glad you did.
Good idea don’t crank down on exhaust bolts or fittings especially manifold bolts they will warp things, these parts get HOT and expand if too tight you will get exhaust bolts snapping off on their own like a bullet.
ok i will get some PB Blaster . and make sure i have a small propane torch handy just incase and :P .
and thank for the info about using the anti seize
i will see if i can get a before and after video of the sound of the exhaust from stock to higher flow
