v6 pushing 35s
Old Apr 17, 2012 | 05:35 PM
dakotaguy1994's Avatar
dakotaguy1994
Default v6 pushing 35s
okay so i want to have a project, not anytime soon maybe start by end of summer but i want to get your opinons on a v6 lifted with 35's
will 35s be possible to push with a v6? will i have to regear it?
what problems will i face with the front axle...
and all that other bs....
suggestions? comments ?
Old Apr 17, 2012 | 07:08 PM
dirtbiker's Avatar
dirtbiker
It can do it, just probably not very well... My 3.9 with a 3.55 open rear end (2wd) is pushing 31's, and I feel anything bigger with stock gears would not do too well at all. So regear if you do it.
Old Apr 17, 2012 | 07:13 PM
dakotaguy1994
forgot to add 99 dakota 3.9 4x4... im pushing 31s also right now
Old Apr 17, 2012 | 09:13 PM
dodgeramguy85's Avatar
dodgeramguy85
I would upgrade gears probably 4.10's or 4.56's
Old Apr 17, 2012 | 09:17 PM
dakotaguy1994
with changing the gears it would make it easier on the trans right?
i would eventually want to swap in a 5.2 or something , because we all know the 3.9 is slow
Old Apr 17, 2012 | 11:05 PM
dirtbiker's Avatar
dirtbiker
Changing the gears will make it easier on everything... I'd go 4.56 gears with 33 inch tires on a 3.9.
Old Apr 17, 2012 | 11:07 PM
dodgeramguy85
Yes it will make it easier. How soon you wanna do the 5.2 swap?
Old Apr 17, 2012 | 11:23 PM
dakotaguy1994
i wouldnt even bother changing the gears if i was going to go up 2 inches, but i feel like if i want to lift the thing i want to do it on 35s, dakotas look good on 35's but 33s just aint doing it for me ya know
i mean i would avoid it for a while if possible, i only got 90 k on my truck and motors clean and trans is fine.
Old Apr 18, 2012 | 12:39 AM
00daksport25's Avatar
00daksport25
I know a guy with the 4 banger Jeep(coincidently the same 4 banger as dakota's) running 40's with 5.88 gears. Point is that it isn't really about engine power as it is about gearing.
Old Apr 18, 2012 | 12:52 AM
dodgeramguy85
You would be surprised at the power bigger tires suck down. I had a 5.2 and when I put 32x11.50x15's on I could feel the difference in power(not much but some) but I did have 3.55's. That was before I had a sct tho.
