Electrical ISSUES Please Help
Sorry but this will be long. Bought a 2000 Dakota last week. The truck sat for appx 1.5 yrs. I expected little stuff, no worries. Today I ran errands and started and stopped the truck at least 8 times no problem. The last stop I locked the truck from the drivers door and when I came out I got the selinoid click on the starter then nothing. I figured a dead battery. Nope. Full charge. No lights, buzzers or anything in the cab. Ignition key is as if the battery isn't hooked up at all. I have power to both fuse panels. I have tested each fuse in the bus and have power on both sides of the fuse. I have replaced the motor to body ground and removed, cleaned and replaced the battery to body ground. I have power on both sides of the 140 amp alt fuse. WTF. Please help. Not sure where to look now.
Put a meter on the battery and have a friend turn the key. What happens to the voltage? Where checking for voltage drop.
How are all the battery connections? The cables can corrode internally and appear to be intact.
