if im stuck in mud were do i attatch to pull out
Old May 19, 2012 | 03:28 PM
Turner661's Avatar
Turner661
Default if im stuck in mud were do i attatch to pull out
knock on wood havent got stuck yet but its the long weekend and i always thought i had hooks in the front bumper ofmy truck cause theres holes on the botom... yea i never looked till today and realized theres nothing in those holes and i have a roll pan in the back as a bumper so cant pull out by that.. so what would you recomend were i should get pulled out by..
Old May 19, 2012 | 04:24 PM
95ram4x4az's Avatar
95ram4x4az
I welded some hooks on front of mine and in rear tow hitch i bought a slide in with a hook on it for rear pull outs
Old May 19, 2012 | 04:56 PM
Turner661's Avatar
Turner661
do you have a picture of how you welded hooks on the front? i had a tow hitch but with a roll pan it doesnt fit right so i was going to either get it custom fited but im planning on getting a body lift so then it would fit but for now im looking to get something in the front or something ..
Old May 19, 2012 | 05:45 PM
Johnn123's Avatar
Johnn123
From the back for sure, just hook to the frame. Theres literally nothing in the front I'm aware of you can hook to that isn't plastic... believe me Ive looked! RWD plus mud dont mix well!
Old May 19, 2012 | 05:56 PM
Jonnymoon5's Avatar
Jonnymoon5
Mine has tow hooks bolted into the front of the frame. I'll post pix when i'm home
Old May 19, 2012 | 06:12 PM
Turner661's Avatar
Turner661
okay thanks man your truck sounds pretty bad *** from the description
Old May 19, 2012 | 10:16 PM
dirtbiker's Avatar
dirtbiker
I would try not to hook to the front of the frame if possible. Whenever (not often) I'm stuck, I hook to my hitch or if it's real stuck I just find a good piece of frame to hook on to.
Old May 19, 2012 | 10:31 PM
jondakotaguy's Avatar
jondakotaguy
There seems to be a pretty stout cross member there the skid plate is mounting too.. what about that? Other than the potential of screwing up the bumper cover?
Old May 20, 2012 | 09:08 PM
Jonnymoon5's Avatar
Jonnymoon5
Thanks bro. just got her last week
They're mounted with 2 grade 8 bolts going through the tow hooks and in the frame. It has 2 sleeves that hold the tow hooks in place in the middle of the bolts in the frame. just needed some trimming of the bumper cover on the bottom and the top of the vent holes for the hooks to clear and for straps to slip onto them. I'm looking to get a front 2" receiver hitch for it soon to have a 3rd recovery point that's centered.
Old May 24, 2012 | 11:09 PM
ahsnowlover's Avatar
ahsnowlover
I made a grill guard and welded a hook on each side of it and mounted it up between bumper mounts and the frame with grade 8 bolts
